http://www.hobid.com/inventory/D/25.html
Hobits to say D9DBV ic is 37-e .İs it true.We can trust to hobit.Where is gandalf gandalf.:stick:
Most likely they are D9GKX...Quote:
Originally Posted by gregorisvas
Anyway I can get some D9DBV too, are they any good ? Did somebody already tried oc'ing these chips ?
how's ecc ram on normal boards? will it work?
I found some that look like fatbodies
3200 ddr2 ECC
5GAll
D9FJC
It works perfect . If your motherboard's chipset support ECC DRAM , then you will benefit some more Mhz .Quote:
Originally Posted by ArcTan
how's D9FJC though?Quote:
Originally Posted by Stelios
Does your modules have parity chips ???Quote:
Count the chips and if you find 9 per side , then they have ECC . If you count 8 per side , then it's non-ECC .
D9DPQ
Are they any good? :confused:
They look like this
http://img243.imageshack.us/img243/3408/de1ld2.th.jpg
mushkin eXtreme Performance 2GB (2 x 1GB) 240-Pin DDR2 SDRAM Unbuffered DDR2 800 (PC2 6400) System Memory
Model #: 991473
That's the kit I have had for like a year. Problem is they don't seem to want to even hit DDR2-1000?
They look very old, how old is that set ?Quote:
Originally Posted by horrorwood
Bought some CM2X512-8000UL's in FRY's today. Suprised:woot: Ithought they were history. I will take them back to Norway and test them in 2 weeks time. Do be good to be........????????????:cool:
Sorry for the spelling mistakes, I am still in shock:p:
Fat Body.
http://img227.imageshack.us/img227/9775/micron2qv0.jpg
Are they all good, or are there also some bad chips ?
And with small memory chips ?
Overclocks it good, or bad ?
http://img134.imageshack.us/img134/1078/micsn3.jpg
Fat body (good) : D9DQT, D9DQW Fatbody low speedbinds: D9CRZQuote:
Originally Posted by nFo
Sqaure (good): D9GKX, D9GMH low speedbinds: D9GCT
Do not buy any other chips, this are the only well clocking (>500mhz) capable D9 as far as I know
Oke, thanks.Quote:
Originally Posted by DaWaN
wich ic's are the ballistix 2x1gb pc6400 using now?
D9MGH, i thinkQuote:
Originally Posted by fscussel
Long story short I was doing some cleanup in a back room at work today and found 2 sticks of these,
http://i88.photobucket.com/albums/k1...c/DSC00186.jpg
http://i88.photobucket.com/albums/k1...c/DSC00192.jpg
http://i88.photobucket.com/albums/k1...c/DSC00188.jpg
I did some looking into and found out that these D9CGH ic's are BT-37E which is the same as the D9DQW ic's. Unfortunatly these look like they are for IBM servers and wont plug into our DDR2 slots.:slapass:
Can these ic's be swapped on to a regular ddr2 PCB?:stick:
Yes, at least if you can either reprogram the SPD or have a mainboard that ignores the SPD when the BIOS has useful frequencies.Quote:
Originally Posted by MTP04
We had the same problem before when registered modules showed up with these ICs but the whimp didn't want to solder :)
Well about the SPD there is a sticker on each stick, now im not 100% sure but there is 533 in one of the codes on both sticks so I am assuming its programmed for ddr2-533mhz but like I said im not 100%, i'll take better pictures tomorrow they are at work.Quote:
Originally Posted by uOpt
As far as SPD reprogramming or soldering a different chip I think thats the least of my worry to get these working. If you look closer at the picture there are pins at the bottom insted of gold contacts like regular ddr2.:confused:
Thats what has me thinking the ic's themselfs have to be swapped to "regular" style ddr2 pcb.
Hi guys, I found List of chips used on DDR2 RAM modules maybe it can be added to the first post. The dude's email address is at the bottom.
Updated post #242 with more pic's. Hopefully someone can give me some more insight on how to make them work with our motherboards.:stick:
Oh and good find nicepun!
What about Patriot 800 LL ? :confused:
Check my post #245, there's a list there.Quote:
Originally Posted by Gam3Ra
That would be me. You are the one who emailed me.Quote:
Originally Posted by nicepun
That is correct. Click on 'Micron DDR2 IC Info' in my sig.Quote:
They are also used on regular DDR2 PCBs, but I wouldn't recommend transferring these ICs (as I explained to you in a PM).Quote:
Many thanks for the list r00n :clap: :toast:
