Now thats wishful thinking. Try 3.6-7v might get ya there. I can't even get one of my 512's to run at 260 stable with 3.5-6v. :mad:Quote:
Something interesting on my p4 AI7 board. I had one stick that does 244 at 2-2-2-5 with 3.2v, the other wouldn't quite do 230. I loosened the bad stick to 2-2-2-8 and its running Test 5 at 240 on my other computer right now with no errors. These are going to go in my NF7-S at 2-2-2-11 (best for NF2) so I'm wondering how they'll do on that :)
Maybe this week I'll get a chance to play with it...darn school!
I'm calling shananagans. :moon:Quote:
Originally Posted by Raybo
If he got the ones on the Mushkin PCB, it means he likely has BH5... I wouldn't call shennanigans ;).
I am now up to:
245 @ 3.1 volts
250 @ 3.2 volts
It won't go higher than 250 at any volts that I have tried up to 3.5 volts. :( I got more errors at 3.5 volts than at 3.4 volts. I guess it is time for some burn in. I wanted at least 250 MHz, and that's what I got. It definately does some nice speeds at tight timings at low volts. Thanks for the great sticks Mushkin! So, for < $400, I got 3 GB of Mushkin that reach at least 240 MHz at tight timings and at 3.3 volts. To think that not long ago, one set would go for ~ $350 on eBay. 2 GB of those run in my DFI nForce4 UltraD at 245 MHz at 2-2-2-10, although it requires 2T. It still gets 2780 in memtest. I will update if the burning in helps.
Just to be extra super duper sure; are these the ones we talking about?
Blue dual pack
Thanks.
These are:
http://shop2.outpost.com/product/360...H:MAIN_RSLT_PG
The ones you linked to are the same model #, but Outpost is still selling them cheaply at the moment...
@ Tibu
No, those are not the ones. The ones I ordered were from outpost.com last week. I believe they ran out of the ones that possibly have the BH5 on the Mushkin PCB like I got. The new ones are more likely the IC's that are based on BH5 and perform similarily, and are on Brain Power PCB. To me, the memory with the Mushkin PCB seems a lot more solid than the memory with the Brain Power as far as weight and physical properties. Anyone else notice this? Anyways, the link GoldenTiger gave is correct. My burn-in has started. 250 @ 3.2 volts and 43 passes of memtest error free (only 35 min).
DAMITT! They are different. The ones on newegg are part number : 990992 based off the close up pic of the modules. Also on the pic, the pcb says mushkin enhanced.
What does this mean? Are they UTT or not?
Damn can someone help me out here? I need to order some good/cheap (no more expensive than $170 UTT/BH5 1Gb kit but it HAS to be from newegg. Can anyone suggest a kit that for sure will be UTT?
No, they're not different. The sticks are labelled that even in dual packs... see this outpost page, it has the single stick of the same thing listed as 990922:Quote:
Originally Posted by Tibu
http://shop2.outpost.com/product/429...H:MAIN_RSLT_PG
I don't know for sure they're the same modules, but the model numbers are indeed the same. The photo at newegg looks nothing like my modules that I got in two dual packs from Outpost (different color heatspreader, different label layout, and different PCB color), but newegg's photos are often of older models if it's an already-existing product that has been changed recently.
Your best bet for UTT from newegg would be the TwinMOS Speed Premium PC3200. Those are $55 now. I am thinking of picking up a pair myself. I did get a dual set of TMII400, but those are not as likely to be UTT. I got lucky and did get some, and they did 256 MHz at 3.5 volts dual channel with 2-2-2-10-1T timings. Be prepared to give some high voltages, which you most likely already know.
Damn, getting the blue pack from Newegg is a gamble... Course the others are a gamble too but... I don't like those silver heatspreaders... What to do... I wish the Mushkin guy was on.
I agree. If you want guaranteed UTT. Buy the Twinmos speed premium.
Running 260 2-2-2 here with 3.4v
My green PCB Brainpower MUSHKIN BLUE'S (UTT-BH5) are rockin' along at 275mHz, 3.6v.... no problems.
C
Is that the set you just recently purchased (for $55/stick) or is that an earlier set?Quote:
Originally Posted by sparkie34
I just ordered two sticks last night, but because I'm paying by check, it won't get here until right about the Holidays....Christmas 2005, that is.
Originally Posted by Reefa_Madness
I got this set about 3 weeks ago. I have 2 more of the $55 sticks on the way. Should be here tomorrow or the next day.
Christmas 05??
Very slow mail service where I live. :)Quote:
Thanks...I saw an earlier post where you had ordered, but I didn't know if you had gotten them yet.
I decided to interrupt my burning in for a little while to test each stick individually. The first stick will do:
260 @ 3.2 volts
265 @ 3.3 and 3.4 volts
272 @ 3.5 volts
The second (crappy) stick will do:
250 @ 3.2 volts
255 @ 3.3 - 3.5 volts
I will now continue the burning process.
Duonger, do you think I can RMA the crappy stick for one that can match my first stick? :D
lol.... I bet they pass DDR400 spec ;)Quote:
C
I have some Mushkin blue coming my way shortly. A friend of mine bought it from Fry's in L.A. last week (or so I understood :) ) What are the chances that I threw away $130 and these are NOT UTT with BP pcb??
Of course I can wait a couple of days and answer this question myself but I just had an "anxiety attack". :D
Also... Since the dimms are ...heatspreadered how can you tell it's UTT aside from testing them of course.
Hi all, why not reporting your results in this thread :
http://xtremesystems.org/forums/showthread.php?t=50699
There is UTT but new BH5 as well in this BDD
My sticks seem to max out at 230 5-2-2-2 2t
Tested up to 3.5 vdimm and no help..
Im sad.
Which sticks are they? The Dual Black or the single greens?Quote:
Originally Posted by xxORBxx
musk
Here some Twinmos Speed Premium PC3500@3.55V
http://img126.exs.cx/img126/9976/sppc35004xf.jpg
