Originally Posted by Saruji
I am the source and I work for Mushkin and built those puppies up.... I am building 4000 more right now so the source is :banana:
Duonger
Duonger
Quiet a weird problem here:
I always get one error in test7 memtest (v1.52 if I remember) and I always get it at 95.5mb?
Tried 2-3-2-6 1T as well as 3-3-3-11 2T but doesn't make a difference :stick:
Both at 2.88V VDimm (max I can give it atm)
I'll now trie another stick, but what do you guys think it is? Corrupt stick? Not enough Voltage?
ashe.....only 2.88 ? omg that's nothing
try 220 2-2-2-5 !!!! not 2-3-2-6
Hi Mushkin Source, nice to meet ya ;)Quote:
Originally Posted by Duonger
I got one stick hier a cannot set into the DIMM-Socket because the HS sees to be displaced. (sorry I cannot explain it, my english is just to bad :() I'l try to take some pictures
Yea, i'll flash my bios to be able to give ~3.2VQuote:
Originally Posted by TEDY
any 2-2-2-x setting won't work with 2.88V
You think it is the low voltage holding me off? Would be UTT chips then, wouldn't it?
Ashe, where do you live.. contact our RMA dept and we will swap it out for you...
800-569-1868 or post in our forums.
Duonger
yep they need 3.0v+
I live in Germany, i'll contact you later this day :)Quote:
This stuff starts anoying me:
With stick 1 I get 7 errors in memtest, all test 7
stick 2 gives me 2 errors in memtest, both test 7 as well
running 2-2-2-5 @3.08V
Did I get crappy sticks or am I doing something wrong? :slap:
edit: passed memtest @ 3.3V (Skipped 3.2V), no going for some oc
Tiger, UTT is not BH-5, UTT is actually the new CH-5. The BH-5 used in the Mushkin Blue is actual BH-5 ICs, not UTT. They are not Speed Binned or tested so you are taking a chance, but so far performance has been good with them. I should be getting my 4 sticks tomorrow or Friday, then I'll be stressing them all weekend and finding the best 2.
And its these ones:
http://shop4.outpost.com/product/360...H:MAIN_RSLT_PG
so do the dual packs come with black BP pcb also? I love these black pcb :D
awwww you have to be kidding......i cant tell my dad i want to return the sticks the day i got them :(
i bought two seperate ones, but at least i got black pcb
:dammit:
Lolz ok cool, sweet to have someone that builds these so close. So part # 990992 is bh5 and ch5, but the dual packs are bh5 ic's right (PART#991140)? Of which you are making 4000 more of yes?Quote:
So, what are my chances of BH5 on 4x 512mb Blue for all of them? Should I refuse shipment? I want the good stuff that's like my BH-5/6 :)! Thanks!Quote:
Originally Posted by cartmanea
the single modules are 50/50.... some are made with bh and others with ch.
if you get the dual packs, then it it guaranteed bh.
Duonger
er...is PCB color just looks or is there a difference between the modules with blue and black PCB's?
Hmm, I wonder if you can do that and then have outpost credit the money back.Quote:
Originally Posted by GoldenTiger
I just recieved my sticks, one black PCB and one green PCB, I hope they have the same chips. :para:Quote:
Originally Posted by Playful_Buffalo
You should be lucky to have one with green pcbQuote:
Originally Posted by Raybo
Got 4 with black here and they suck (so far ;))
#1 doesn't seem to do anything (not SPD @2.8V, not 3-3-3@2.8V, not 2-2-2-5 @3.3V)
#2 doesn't fit into the DIMM-Slot :D
#3 at least hits 220 2-2-2-5 @3.3V
#4 is currently doing 225 2-2-2-5 @3.3V but still gets 3 errors 16 loops memtest (test5)
Don't want do give up yet but it's pretty depressing to have 3 crappy sticks and one that cannot even be tested :(
I'll try to do a VDimm-Mod and get a newer bios, but my hope is fading :shakes:
nevermind
EDITED
I wouldn't say that ;)Quote:
I'm quite a noob concerning overclocking and I have a feeling my motherboard (or the old bios) doesn't like the Mushkins
So you guys are telling me I got 4 BH-5 sitting here? That just sounds too good to be true for the price. My luck has turned upward for once...
i like that guaranteed up there
That's the spirit, don't give up on 'em yet. List some of your gear and we might be able to help a little better. You might just need to fiddle with a BIOS setting or two to get your sticks to sing. :banana:Quote:
Originally Posted by Ashe
So, how do the "other" sticks perform? Am I likely to be disappointed? Should I try to switch to 2 dual packs now?
