Im going to point MSI at this thread and see if they can help.Quote:
why are you guys messing with dividers? doesn't that sort of defeat the purpose?
yeah high 1:1 is best for AMD64Quote:
Originally Posted by xgman
Hey I'm no whore!! :smileysex :devil:Quote:
Originally Posted by bigtoe
For real though, OCZ is the most devoted company we have for us xtreme enthusiasts. Just be patient and they will get us more VX soon. I know none of us like to wait, but would we rather have un tested IC's on the VX that'll only do pc3200?
eva, there is no such thing as 1:1 on A64, memory runs based on a CPU divider, not HTT (FSB).
Dividers such as 166, 183, etc... just change the divider that is used based on the CPU speed.
Many times you can optimize your CPU speed, by using a divider, effectively increasing your multiplier (if you imagined the multiplier to be RAM speed x Multi = CPU speed)
Of course if you have an FX chip, then there is no reason to play with dividers :) But for those stuck with a 9x multi, dividers can be a huge improvement...
BTW, for those looking to buy VX, these guys look like they are in stock (ship worldwide as well) if you don't mind paying a little extra:
http://www.microstorm.com/OCZ_1GB_51...id-529218.html
it's out of stock, pretty much EVERYWHERE......
glad i jumped in on it when i did!
Don't worry, unless I get 260+ dual channel 2-2-2-x, I will be selling my 4 pieces or something and look for BH-5 instead. Per price, it's 1:1 seems good but that doesn't take into account of divider unfortunately which is big turn off for me. (even if I get FX).
I've got my VX on a trial base for now, so i'm just waiting a bit to see if there is a solution to this divider problem. My 3000+ is running at 3000mhz 1.6v prime stable for hours .. i was hoping on the vx to use the 166 divider. Let's wait and see.
166 issue update.
We have programmed VX with a TCCD and EB spd and it made no difference...the modules still didn't like 166 mode.
We have a theory as to why but its best we work with bios engineers to see if we can resolve the issue.
So for now we are advising VX is best in 1:1 mode, some will do ok in 166 mode but your not going to see 300+HTT.
I have started asking if bios files can help, as soon as i know more i will post.
so it definetely is some sort of VX compatibility issue, right? hope you guys can fix this with co-op with BIOS engineers.Quote:
on a side note - ATM, after being able to do DDR512 6-2-2-2.0 1T i'm not even able to memtest @ DDR400 :( checked in NF2 mobo and it runs fine with no memtest error. put back some BH-5 in my Neo2 and it works fine too..... i thiunk i exhausted all ideas i had :(
update: and for this situation to look even "better" - i already pulled off heatspreaders :(
Guys pulling off heatspreaders is always a bad move...with our ddr2 it can pull off IC's also :eek:
bachus_anonym you saying your ram is ok in NF2 but not your MSI?
Thanks m8 on the update. We will be praying for some kind of solution. :)Quote:
tiny BGA have weaker joints to pcb so yup pulling off heatspreader will take a few things off the pcb heheQuote:
I gained 2MHz by pulling off my heatspreaders. I'm pretty sure I was the first one here to do this. :D If voiding your lifetime warranty for 2MHz sounds good to you, go for it - just be careful not to accidentally yank anything else off.
Which brings up a good point....Quote:
Originally Posted by conrad.maranan
"OCZ, if you guys spend so much time and expense binning and testing chips, then stick heatsinks on them and reduce their performance?????
Why not just include heatsinks in the package with frag tape?? User option, you know?
I think this would be a good idea. For sure, case modders love the bling effect of gold and silver heatspreaders. But enthusiasts who care more about the bottom-line performance of a component can definitely appreciate a naked stick of RAM. Off the top of my head, the G.Skill modules serve as a fine example.Quote:
Originally Posted by charlie
heh, reminds me of the thread in which the guy watercooled his ram
EDIT: here you go
Well, you sure about that? 6 sticks tested so far (2 from RMA) and 1 didn't even hit stock speed 2-2-2-x on 3.5v, now I am just toying with one of RMA'd stick that is keep going down to what seems to be stock speed from 240 below. (@ 215 testing right as I write this....)Quote:
No, it isn't my machine as the other 4 sticks did just fine above 240. If not higher (to 267).
I plan to call and RMA again. However, the cost of shipping this memory back and forth are really adding up. So far, amount of money I had to spend on OCZ RMA is adding up close to $30 with memories, etc.
yes sir.... VX is in my day-to-day rig, NF7-S v2, running at DDR433. i've tried memtest on them and it runs just fine. when i had it in MSI, i get errors right after test #1 :confused: and 99% of them at the same address 308.5MB...Quote:
so for now i put my 2x256MB BH-5 in Neo2 and it runs absolutely fine @ DDR520 (no errors in memtest).
i now recall that this happened BEFORE i removed heatspreaders but AFTER i started playing with memory dividers.... i think i need to look into little bit closer coz it looks like RAM is fine....
EDIT: i just want to repeat that just few days ago i was error-free @ DDR512 and benchmark-stable up to DDR524....
Looks like the same thing that happened to trans am is also happening to you. In the end, I believe he was only able to run at stock speeds.
*interested onlooker - now concerned with his recent order of vx*
well it seems that I'm one of the lucky owners of this VX memory, got it today together with the DDR Booster, I'll be picking up my ASUS A8N-SLI later this day since they held one back for me :toast:
Now my question is has anyone yet tried the VX together with the Booster on the A8N-SLI? I've saved quit a while for this beast and don't want to fry anything (well at least not in the first month :p: )
hmm i wouldn't try it on a board that will be hard to RMA, might want to wait and see what andy says, he trys the booster on a variety of boards.
I think VX is great for FX where you can use high multi and run VX at it's highest stable ceiling, or a single channel setup. But I think if you ran a divider on the VX, you are better off getting some good tccd and running that at high speeds. I've had 2 sets of VX with 3 different cpus and 3 boards. they both max around 240-245. I think opp got really lucky and this is not normal for VX> don't get your hopes up and think you are going to hit 260mhz out of the box with these. IMO you will be extremely lucky to hit 250mhz stable. I'm not trying to stomp anyones buzz, I'm just being realistic and don't want people to commit suicide because they didn't get their VX past 260mhz. As for the divider issue, I coun't get any divider to work on the neo2 no matter what speed, on any bios except the 100 divider out of the bios., I could change dividers 166/133 etc with A64 tweaker and it worked, but would fail to load os when dividers set in the bios. My heatspreaders came off the day I got mine. I think it's a good idea if you have a decent set . They run much much cooler with the spreaders off because air can actually pass between them even using dimm slots 1 and 2. when heatspreaders are on, they end up touching each other generating tons of useless heat. Take it all off.Quote:
Originally Posted by bachus_anonym
