However the prices in Europe are outrageous comparing with the ones in usa. Not only talking about ocz but for all.Quote:
georgesod it is still a luck for you in here we dont even find good rams
Can sombody PM me when someone in UK sells them? ?
I wanna get some soon and I missed the gladiator selling them, they not sell 1gig anymore, only 512VX ram, but if i buy two 512sticks, I can run them in dual channel and there just like buying 1 gig (2x 512) ?
Neither do we. We just order them from online shops, pcmemoryupgrade for exampleQuote:
Originally Posted by kromosto
Originally Posted by Nube
link
errhhh... sorry to say, but YOU WERE one to begin with (the P W) before you joined OCZ :) Not that it was bad thing. Lot of people benefitted from your experiments and some conflicting investigation with eva2000 or someone :)Quote:
Let's hope we can find something about the divider issue of VX soon before we can claim it to be best memory made since BH5 though :). A little surprised that there was no divider test done on MSI K8N neo2 or I bet half the people with Phase cooling wouldn't have bothered with it to begin with...
(Bios 1.3,1.36,1.37,1.4,1.41,1.51 doesn't fix this issue at all)
Let's see how it unfolds.
yeah, that divider issue really suxx.... i still believe it must be BIOS related / a way board handles VX...
OCZ really needs to look into it....
I never tryed a divider with this memory.Quote:
Originally Posted by jinu117
What seems to be the issue?
I'll have to plug in the VX today and see what your reffering to.
OPP
check that, OPP please....Quote:
Originally Posted by OPPAINTER
well, what happens is that above 270ish (no matter what multi, it seems) we get NO POST with memory divider of 166...
i'm playing with it now and it seems that once mems hit DDR446 with 166 divider system either doesn't POST or crashes (if upping HTT with clockgen in Windows)...
And yes, OPP. Would appreciate if you can find out if other boards such as Asus or s754 have same issues if you happen to have them handy :P Want to know if it is mobo issue, chipset issue, or bios issue, or something.
Stock:Quote:
Originally Posted by georgesod
Out (no ETA)
I have been able to run 275+ 166 mode on the epox 9NDA3+ and had no issues 133 mode either...i know some boards may have some issues but it may not be the ram here but I will look into it for you.
TBH you guys are going to want to run 1:1 as it is the fastest mode, don't go off buffered sandra use the unbuffered and use everest to compare..you will see what i mean.
but u see, the problem is that with divider issue this memory is useless for those that wish to run it in phase change systems... 256x10=2560MHz is OK with div 200 but e.g 285x9=2565MHz or 285x10=2850MHz with div 166 will be impossible.... :(Quote:
EDIT: have u tried e.g. 280HTT with div 166 ??? i can POST up to 279HTT but only 270HTT makes it's way all the way to Windows. but unfortunately it's totally unstable there :(
Mine will POST and go into windows at 275 on 200MHz (1:1) divider... will try divider and >280HTT tonight
Well sure enough, I just tryed the 166 divider on MSI Neo2. The system was all FUBAR after 270HTT:D.
I don't have other boards to mess with at the moment. Waiting on some NF-4 and ATI 480 boards next week.
I can see how some people with locked multis won't appreaciate the memory.
I myself am not worried about a divider issue for my rigs. 1:1 is my goal.
OPP
so in other words, if one's going for OCZ VX on phase change beyond 2900Mhz - better one gets himself FX.... :D hmmm.... that FX just got few places up on my "to-upgrade" list :)Quote:
FX is the only way to Fly:D
OPP
VX for FX .. kinda has a rhyme to it.. :D
If I get really nice batch of VX for this RMA... than maybe. 270 2-2-2-8 dual channel will be nice enough to consider it's fault (or mobo's fault) with divider and move on to FX. We are entering the first batch of 875p era kind of problem. (It was chaotic era with everyone scrambling to figure out what works and what not)
above 275mhz with the 166 divider i can't boot either.
also is my friend, too. guess everyone with the neo2 board may have the
same problem.
Im going to point MSI at this thread and see if they can help.Quote:
Originally Posted by formyfaith
why are you guys messing with dividers? doesn't that sort of defeat the purpose?
yeah high 1:1 is best for AMD64Quote:
Originally Posted by xgman
Hey I'm no whore!! :smileysex :devil:Quote:
For real though, OCZ is the most devoted company we have for us xtreme enthusiasts. Just be patient and they will get us more VX soon. I know none of us like to wait, but would we rather have un tested IC's on the VX that'll only do pc3200?
eva, there is no such thing as 1:1 on A64, memory runs based on a CPU divider, not HTT (FSB).
Dividers such as 166, 183, etc... just change the divider that is used based on the CPU speed.
Many times you can optimize your CPU speed, by using a divider, effectively increasing your multiplier (if you imagined the multiplier to be RAM speed x Multi = CPU speed)
Of course if you have an FX chip, then there is no reason to play with dividers :) But for those stuck with a 9x multi, dividers can be a huge improvement...
BTW, for those looking to buy VX, these guys look like they are in stock (ship worldwide as well) if you don't mind paying a little extra:
http://www.microstorm.com/OCZ_1GB_51...id-529218.html
it's out of stock, pretty much EVERYWHERE......
glad i jumped in on it when i did!
Don't worry, unless I get 260+ dual channel 2-2-2-x, I will be selling my 4 pieces or something and look for BH-5 instead. Per price, it's 1:1 seems good but that doesn't take into account of divider unfortunately which is big turn off for me. (even if I get FX).
I've got my VX on a trial base for now, so i'm just waiting a bit to see if there is a solution to this divider problem. My 3000+ is running at 3000mhz 1.6v prime stable for hours .. i was hoping on the vx to use the 166 divider. Let's wait and see.
166 issue update.
We have programmed VX with a TCCD and EB spd and it made no difference...the modules still didn't like 166 mode.
We have a theory as to why but its best we work with bios engineers to see if we can resolve the issue.
So for now we are advising VX is best in 1:1 mode, some will do ok in 166 mode but your not going to see 300+HTT.
I have started asking if bios files can help, as soon as i know more i will post.
so it definetely is some sort of VX compatibility issue, right? hope you guys can fix this with co-op with BIOS engineers.Quote:
on a side note - ATM, after being able to do DDR512 6-2-2-2.0 1T i'm not even able to memtest @ DDR400 :( checked in NF2 mobo and it runs fine with no memtest error. put back some BH-5 in my Neo2 and it works fine too..... i thiunk i exhausted all ideas i had :(
update: and for this situation to look even "better" - i already pulled off heatspreaders :(
Guys pulling off heatspreaders is always a bad move...with our ddr2 it can pull off IC's also :eek:
bachus_anonym you saying your ram is ok in NF2 but not your MSI?
Thanks m8 on the update. We will be praying for some kind of solution. :)Quote:
tiny BGA have weaker joints to pcb so yup pulling off heatspreader will take a few things off the pcb heheQuote:
I gained 2MHz by pulling off my heatspreaders. I'm pretty sure I was the first one here to do this. :D If voiding your lifetime warranty for 2MHz sounds good to you, go for it - just be careful not to accidentally yank anything else off.
Which brings up a good point....Quote:
Originally Posted by conrad.maranan
"OCZ, if you guys spend so much time and expense binning and testing chips, then stick heatsinks on them and reduce their performance?????
Why not just include heatsinks in the package with frag tape?? User option, you know?
I think this would be a good idea. For sure, case modders love the bling effect of gold and silver heatspreaders. But enthusiasts who care more about the bottom-line performance of a component can definitely appreciate a naked stick of RAM. Off the top of my head, the G.Skill modules serve as a fine example.Quote:
Originally Posted by charlie
heh, reminds me of the thread in which the guy watercooled his ram
EDIT: here you go
Well, you sure about that? 6 sticks tested so far (2 from RMA) and 1 didn't even hit stock speed 2-2-2-x on 3.5v, now I am just toying with one of RMA'd stick that is keep going down to what seems to be stock speed from 240 below. (@ 215 testing right as I write this....)Quote:
No, it isn't my machine as the other 4 sticks did just fine above 240. If not higher (to 267).
I plan to call and RMA again. However, the cost of shipping this memory back and forth are really adding up. So far, amount of money I had to spend on OCZ RMA is adding up close to $30 with memories, etc.
yes sir.... VX is in my day-to-day rig, NF7-S v2, running at DDR433. i've tried memtest on them and it runs just fine. when i had it in MSI, i get errors right after test #1 :confused: and 99% of them at the same address 308.5MB...Quote:
so for now i put my 2x256MB BH-5 in Neo2 and it runs absolutely fine @ DDR520 (no errors in memtest).
i now recall that this happened BEFORE i removed heatspreaders but AFTER i started playing with memory dividers.... i think i need to look into little bit closer coz it looks like RAM is fine....
EDIT: i just want to repeat that just few days ago i was error-free @ DDR512 and benchmark-stable up to DDR524....
Looks like the same thing that happened to trans am is also happening to you. In the end, I believe he was only able to run at stock speeds.
*interested onlooker - now concerned with his recent order of vx*
well it seems that I'm one of the lucky owners of this VX memory, got it today together with the DDR Booster, I'll be picking up my ASUS A8N-SLI later this day since they held one back for me :toast:
Now my question is has anyone yet tried the VX together with the Booster on the A8N-SLI? I've saved quit a while for this beast and don't want to fry anything (well at least not in the first month :p: )
hmm i wouldn't try it on a board that will be hard to RMA, might want to wait and see what andy says, he trys the booster on a variety of boards.
I think VX is great for FX where you can use high multi and run VX at it's highest stable ceiling, or a single channel setup. But I think if you ran a divider on the VX, you are better off getting some good tccd and running that at high speeds. I've had 2 sets of VX with 3 different cpus and 3 boards. they both max around 240-245. I think opp got really lucky and this is not normal for VX> don't get your hopes up and think you are going to hit 260mhz out of the box with these. IMO you will be extremely lucky to hit 250mhz stable. I'm not trying to stomp anyones buzz, I'm just being realistic and don't want people to commit suicide because they didn't get their VX past 260mhz. As for the divider issue, I coun't get any divider to work on the neo2 no matter what speed, on any bios except the 100 divider out of the bios., I could change dividers 166/133 etc with A64 tweaker and it worked, but would fail to load os when dividers set in the bios. My heatspreaders came off the day I got mine. I think it's a good idea if you have a decent set . They run much much cooler with the spreaders off because air can actually pass between them even using dimm slots 1 and 2. when heatspreaders are on, they end up touching each other generating tons of useless heat. Take it all off.Quote:
Originally Posted by bachus_anonym
have you burnt in the VX yet ?Quote:
Originally Posted by trans am
Burn in?Quote:
Originally Posted by eva2000
as in countless hours of test 5 and hot cpu tester? Yes, been there done that. lol
Burn in seems real for me... by about 3-6mhz on each stick except the one that is doing 267-2-2-2-8. Wonder if it has to do with heatspreader settling down or something. BTW, whoever keeps saying this memory runs cool even at high volt is smoking something or running it @ stock speed with high volt. It seems like temperature escalates rather quickly when you have over 3.3+v and actually stressing memory. I've seen so far up to 50c on pcb section of memory. with 2 32cfm 80mm fan blowing directly above that area.
PS) I am getting another set sent out from OCZ today. By thursday hopefully I will have some magic clocker. One thing I found out, they pretest memory without heatspreader. Don't want to invalidate warranty yet but when my stick becomes old it might be worth the fun to take out.
I'm not smoking anything nor am I running it at stock. my spreaders are off and I have 90mm panaflo blowing on ddr booster and dimms. Of course memory is not cool, it's not scalding my fingers when I touch it either. THe heatspreaders were really hot before I removed them, even with the panaflo.
If the divider issue gets solved with the neo 2 board,
I think VX would start to rock~! :)
I hope msi gets this problem fixed really fast~ :D
thanks a lot bigtoe :toast:
I wouldn't dare accusing you of smoking something... maybe sniffing cat stuff lol :)Quote:
Got any temperature measure probe to check the temp real time while it is running? I really think this heatspreaders are nothing more than heat trappers.
Truth.Quote:
I tested at 3.5v 260mhz with VX with some good ventilation in the form of a strong 80mm fan and using my digital thermometer if found nothing higher that 32C. I also probed the actual IC's under the heatspreader (from the side of course) and found nothing higher than 32c.Quote:
I suggest that either your voltages are off (high) or you need better ventilation. :)
Would it not be cheaper to produce VX without heat spreaders? I know some people think RAM cannot be high-performing without heat spreaders, but those kind of n00bs would not be into buying RAM that needs 3.3V to perform. You could call this new heat spreaderless RAM OCZ VX Lite or something. I'd buy some.
All my testing was done inside the case with no fan blowing on them. I can't wait to get these on the Test Bench try some cooling, might get me some extra hertz:D
OPP
I think one of the reasons they use heatspreaders is to help prevent ESD, otherwise they probably would be making them without heatspreaders. Just a guess though, I may be wrong.Quote:
Originally Posted by mcnbns
i think it's more of a "BLING BLING" factor. It's a status thing lol. you gotta have 'Bling' in order to have street cred. these days.
It's alright if my system is lacking in the rave lighting and hip hop shine department. I can always throw in a couple of pairs of the illest Air Max 87s and 90s to make my rig really stand out in a picture. Better yet, I can commission some skanks on MySpace to pose with my rig for added effect. :D
LOL conrad, I was thinking about getting some chrome 20" rims for my case. It's so heavy with all this cooling, I need to be able to roll it around. Maybe adding a few 12" subs and a few LCDs in the near future.....Please MTV...Pimp my ride!Quote:
Im going for the ghetto thug angle... lay down a GAT & AK47 beside my system and paint 2Pac on the case window... now that's gangsta! hahaha
Conrad, you realise those modules you have are 10x better than mine... either that or your sis has a CPU with one beaut of a mem controller... granted I can't give my modules more than ~3.35vDimm but they max at bout 261 memtest stable. So either your 3.5v burnin really did wonder, you jus got brilliant sticks, or that CPU you got there needs to be sent this way and fast! :)
