TEDY Tooo lucky :banana:
My 3200VX also need 3.4V for 250Mhz 2-2-2-5
mine do 260 @ 3.2V in memtest all test al day but need 3.4V to be fully stable in windows such as S&M stable.Quote:
Originally Posted by Moonman
i don't get it really........why is this happening ?
Originally Posted by TEDY
well i think its because in memtest the cpu onboard mem controller isnt too involved but once in windows stress testing it is so dimms need extra voltage for the communications between them and controller. at least thats my theory.....
Isn't memtest #8 for windows stability?
doesnt seem to work that way though.
my new SD 3700+ wont go beyond 240FSB so perhaps the bios could be the bugger (310) so which one for my pc4000VX would be the best (wont use 7** ) ? 526 sounded good, but dont know what changes have been made in the 6** and what version to choose.
I would go for 510-2 FIXED (23-06-2005)
just tied with 623-3 ...worked fine at 220FSB it didnt need any extra vcore....but then it was like hitting a brick wall.....230 1.5 in vcore!!! and only stable 240@ 1-6v ....this is very disappointing.
Try these timings/settings: http://www.bleedinedge.com/forum/sho...46&postcount=3Quote:
Originally Posted by [G.N.U.]Fragman
Let us know how you do.
Anyvbody knows how this sticks owrk on DFI NF3 Ultra-D ( my board is great ! )
I think that the VX is great and all, but if you guys really want to overclock your RAM, then you should have gone with the Mushkin RedLine. The RedLine can go up to about DDR587 or something whereas the VX cannot. I have two sticks on the Mushkin RAM and I am very pleased with them; I haven't tried the VX yet though.
VX are super cheap... so even though it doesn't go to those massive speeds, $$$ > small increase in performance. For me anyway.... cos 250mhz VVX is great for me.
well it isnt the RAM that are slowing me down..... 2-3-3-8 @ 250 @ 3.2v is possible....but my cpu wont go stable past 245 with less than 1.65 ....and this is close to my limit...its a 24/7 setup so it must be stable.......dont know how high to go because i dont trust those damn temp sensors @ board..... about 38-40 says ITE on load....XP120 and a 1100RPM revoltec on top.....that seems to me to little to be true.....
does cas 1.5 work better than 2 with these? I have to use 3.5v to get 250mhz stable on DFI Ultra-D
Apparently Cas1.5 does work with these and i'm not sure how much you gain though
Anyone got a Venice running these with dividers and can tell me what settings they use in the BIOS? I'm having a little trouble with the dividers as it's giving me Primeing errors. Rounding times etc.
Hey Guys,
I heard the News BH-5/UTT don't run on S478 Boards/CPUs. They should only run on A64. I have some New BH-5 (noname) running on my S478 P4-M, but it doesn't work good. So this could be right. Can you say me some more about this? In some weeks I want to buy some new Ram and decided to take the OCZ VX Series with the new UTT. But do they run on S478 Boards/CPUs? Or must I take another Ram?
Please help me.
UTT/BH5 are WORKING on S478 . GOt some Twinmos Twister BH5 on my P4C800-E dlx.
just a couple real quick questions
just got some OCZ PC4000 VX..... they are refurb'd tho... will i still need to do the "Burn in" process?
can someone point me to how to do the "Burn IN"
are the PC4000 tested @ 250 for sure.. my corsairs will run 250 but at super loose timings. i can give the UTT 3+ volts..
also which BIOS for DFI SLI-DR...........sorry for the repetitive question.
Just burn them in 250 @ 2-2-2-10 @ 3.3.
I'm testing 257 2-2-2-5 @ 3.3. Looks good so far in memtest #5.
I'm at 2-2-2-5 @ 259 MHz using 3.3V. I don't know if this is g ood or not. 0 errors so far after 10 min of Memtest, but Im surprised it didnt ask for 3.4v by now.... So far so good, but I'll leave it on for a few more hours
That ain't bad dmo...of course we're all interested in what it can do with more voltage though. :p:
not bad huh... nice ram u got :)Quote:
Originally Posted by dmo580
hi, first sorry my english is too bad
i bougth this kit today (i'm from chile) and go to burn process with memtest
i put the rams 200Mhz 2-2-2-x 3.2v but in less than 1 min there are aprox 32 errors
please help
the rams are bad??
3000+ winchester
dfi nf4 ultra-d oskar bios
6800gt
thnx
