Originally Posted by trans am
I think VX is great for FX where you can use high multi and run VX at it's highest stable ceiling, or a single channel setup. But I think if you ran a divider on the VX, you are better off getting some good tccd and running that at high speeds. I've had 2 sets of VX with 3 different cpus and 3 boards. they both max around 240-245. I think opp got really lucky and this is not normal for VX> don't get your hopes up and think you are going to hit 260mhz out of the box with these. IMO you will be extremely lucky to hit 250mhz stable. I'm not trying to stomp anyones buzz, I'm just being realistic and don't want people to commit suicide because they didn't get their VX past 260mhz. As for the divider issue, I coun't get any divider to work on the neo2 no matter what speed, on any bios except the 100 divider out of the bios., I could change dividers 166/133 etc with A64 tweaker and it worked, but would fail to load os when dividers set in the bios.
