Agreed waza takes forever on mechanical, but I just have so many of them :p:
Will give ssd a try for waza and see if I can duplicate my times on a mechanical drive, thanks Sam :up:
I still need to learn how to good run on SPI ...any suggest ? :)
http://i1191.photobucket.com/albums/...pse0e20007.jpg
Some Gigabyte Z97 and Pentium 4Ghz
http://s29.postimg.org/h8stl7don/ggx7.png
http://s4.postimg.org/h7l2u0yil/DSCN9830.jpg
dem buttons :X
XBrytanX - 5:55:703 - 40x125.1 - 1375 MHz - 6-10-6-24-64-1 - Z97 OCF - GSkill 2000 c6 2x2GB/PSC - 2.3V - LN2 @ all
http://i774.photobucket.com/albums/y...ps1e13c03d.png
Update. :)
nice!
Alex-Ro - 5:57:079 - 50x100 - 1466 MHz - 9-12-2-17-108-1 - Maximus VII IMPACT - Corsair Vengeance Pro 2666c10 - 2.15V - air
http://abload.de/img/impactsamsung29335orsr.jpg
So between work and now school, I have gone on the longest vacation from benching due to lack of time and guess what? It sucks:p:
Decided to give the c6 Pi's another run at 5Ghz and after hours I finally managed a 2800 c6 run :yepp:
Checked off the list of :banana::banana::banana::banana: to do :up:
Started the night off good, besting my best time:
http://i.imgur.com/ycpMEMP.png
Different waza yielded slightly better results:
http://i.imgur.com/ZZ8G5f3.png
tightened trfc, small almost unnoticeable gain:
http://i.imgur.com/jE1rStd.png
. . .and then I tested every strap/bclk combo to find out what would run and after hours of fail, I realized this kit can not run TRAS 21 at 2800+ and nothing over 2809 ever passed much less even trained.
l0ud_sil3nc3 - 5:55:063 - 38x131.6 - 1403.6 MHz - 6-10-6-24-64-1 - ASRock Z97 OCF - G.Skill 2000 C6 PI 2x2GB/PSC - 2.22V - LN2 @ all
http://i.imgur.com/O8xbIVL.png
pics:
http://i.imgur.com/T30CWUg.jpg
http://i.imgur.com/DVNvhCR.jpg
http://i.imgur.com/S9wO6jS.jpg
strong numbers :clap:
Booom
Awesome work loud,also looking really good Luke :up:
@ Alex that sammy time is great,considering your CPU speed that would have to be one of the best sammy times I've seen :up:
omg killer score loud wow, you run full pot on your psc kit ?
Just saw Luke's run as well bully, great job chl :)
And crazy RTL Alex, no other board can run Samsung at symmetrical RTL's like the baby Impact.
nXXo I guess the pot was full of LN2 the whole time, but max dimm temps were -136c warming up to -125c by the end of a 32M run, maybe time to start applying TIM on the heat spreaders in between the pot.
And Allen, you are too damn fast lol
way to go LS ....
Well done, George! :clap:
Alex-Ro - 5:56:640 - 47x106.5 - 1490 MHz - 9-12-2-21-110-1 - Maximus VII IMPACT - Corsair Vengeance Pro 2666c10 - 2.30V - air
http://abload.de/img/2980g2j7e.png
Haswell is boxed until new thermo/probe comes :(
nm :p:
Little more out of my old 4770k,had few faster ones but just not passing
bullant - 5:55:094 - 39x128.3 - 1410.8 MHz - 6-10-16-21-64-1 - Z97 OCF - GSkill Pis 2000 cl6 - 2.23v - LN2 -160
http://i62.tinypic.com/msehr9.png
http://i59.tinypic.com/flg6tu.jpg
Forgot to add this entry:
Alex-Ro - 5:56:671 - 50x100.0 - 1466 MHz - 8-12-2-18-108-1 - Maximus VII IMPACT - Corsair Vengeance Pro 2666c10 - 2.35V - dice -50 c
http://abload.de/img/29338-12-12mkoe7.png
Nice work, bullant and Alex-Ro! :clap:
awesome run guys!
How do you set tWTR 3 on asrock? in the same bios 0.12C i only have the option to set "4" and "auto" no 3 lol
Might be a mistread. When I set 4 on ASUS and use ASRock software, it reads 3.
