great mate
do they pass hyperpi ?
this is just a try i copied mostly all your settings except CL11 and 96 zpaf
and look my 2666CL10 they did awesome, i also have yours
http://img842.imageshack.us/img842/6407/capturafx.jpg
Uploaded with ImageShack.us
http://i.imgur.com/U2AVH.jpg
Great kit also see the lit diff and the BIG on volts this is my 24/7
Can anyone pass HyperPi with this kit at 2800 11-13-13?
My kit is 2X4GB can pass SuperPi at the rated specs, 1.65v vdimm, 0.925v VCCSA, 1.15v VCCIO
But failed on HyperPi :(
true but i can pass it stock at 4800 for 5GHz i need a bit more
some screens for you as reference
all are on Lateny boundary 6
http://i.imgur.com/X1Kl1s9.jpg
http://i.imgur.com/CS4mpHv.jpg
hope you get them there owi good luck :up:
Thank you guys... first attempt load XMP #1
2800 11-13-13-35-2T
vdimm 1.65v
VCCSA 1.2v
VCCIO 1.15v
http://i458.photobucket.com/albums/q...65v12v115v.jpg
Somehow 2T seems to be impossible I have tried up till
vdimm 1.8v
VCCSA 1.25v
VCCIO 1.25v
But failed HyperPi within 2 loops.
I can pass hyperpi 32M 2T, yet fail within sec son prime95 blend... daily running 2800MHz are not for most IMC...
i think there?s nothing more painfull to the IMC and MEM than runing 500%+ of memtest
Finally managed to pass HyperPi with G.Skill Trident 2800C11 kit at
2800 11-13-13-35-1T
vdimm 1.775v
VCCSA 1.2v
VCCIO 1.15v
subtimings as per andressergio's settings
http://i458.photobucket.com/albums/q...75v12v115v.jpg
What chips,hynix bfr or cfr?
MFR are 4gbit ICs, if your TridentX aren?t single sided sticks, these will sure be CFR then as these are 2gbit ics = 16 ics, ics on both sides of pcb
Im asking because i tought cfr would not need so Much voltage,my 2800 platinums can do 11-13-12 with 1.69 ....
mines are hynix they pass hyper at 1,65 as shown above even on VCCSA and VCCIO stock
LinX successful @ 2800 11-14-14-25-1T @ 1.66v
http://i458.photobucket.com/albums/q...MVE/502800.jpg
