Hi ~
AMD Phenom II X2 550 BE X4 unlock
I am testing the new X2 550 BE ...
Prime95 START
cpu : 1.15v X2 550BE @ X4 Quad-Core:)
http://cfile2.uf.tistory.com/image/1...4A42378472A9C4
http://cfile21.uf.tistory.com/origin...4A42BC2A48F795
Hi ~
Prime95 START
My 0922APMW code 550BE
Air cooling
http://www.playwares.com/xe/files/at.../117/005/1.JPG
AMD 550BE @ X-4 4G 1MB Pi
http://cfile21.uf.tistory.com/origin...4A438DD931BABA
AMD 550BE @ X-4 4G 32MB Pi
http://cfile5.uf.tistory.com/origina...4A438DD83073B0
http://valid.canardpc.com/show_oc.php?id=592803
http://www.playwares.com/xe/files/at...5/IMG_5028.JPG
Max Clock
dont feel so bad im in the same boat as you.
i have a newer stepping aswell, CACYC AC 0932FPMW but i have heard of acouple people getting those to unlock aswell.
my 790FXB-M2RSH doesnt seem to wanna do it no matter what i do. it just doesnt post once i set it. i have tried almost all the bios execept the one without the zip file. (27)
im not really sure what i should set everything else incase thats whats messing it up.
im running ddr2-1000's so i duno if i should tinker around with the ht setting cause everything is on auto and should sort itself out.
id like to believe that i could get at least 1 core working but this mobo seems to be um.. annoying to deal with to say the least.
Your chip is bad, man, that DFI will unlock 100% stable.
I used that mobo to unlock a 720 and three deneb 5000+, all were very easy to do and all those chips were good. I was using the August 20 bios for all of that, and everything worked perfect and the chips would clock clear up until either their limit or the DFI's HT Ref limit with 100% stability.
I would try each ACC value between -12 and 12 on all the cores and see what happens. If that fails, try vcore, but it's likely that your chip is not a good unlocker.
4140MHz on air, and 4020 as a QUAD here. 0929BPMW
that may be so but im not convinced yet. i think my board could be buggered as it has been sent it for repairs to the manufacturer and i know for a fact it was repaired and not replaced so i have doubts on the credibility of it.
which is why im looking for somone local who would be willing to test my cpu for me ;)
also someone who bought the cpu the same day as me with the same batch or stepping number on it was a success so :shrug:
damn cozmosland, 0 post in 4 years and 3 in last 2 days?! impressive! :p:
haha your a big help. lol
i duno.. i cant even remember signing up. i guess iv never really needed help until now haha.
dont put it against me :P
