ROFL!!! What's your paypal address for me to send you $100, once you're finished with making a nice sliders GUI? I'll send you $100 monopoly bucks!!!
Here ya's go, a GUI for ya's..with sliders for the folks that were obsessed with them :D
It's pretty simple, it doesn't read anything in realtime. It's not too useful, only eases finding the voltages you want @ your stable clocks. After that, it's alot easier to use rivatuners scheduler to apply settings at windows startup.
The GUI just increments the VID values via the slider, and shows the appropriate conversion in volts. Adjust the slider, and hit the Set Voltage button, and both 2D and 3D voltages are set. Nothing is applied until you hit the Set Voltage button.
And easy check to see if all is working good it to open furmark (no need to start it), check 3D voltage. close all 3d apps, check idle voltage
It works for 280gtx for IC2 Bus value of 3, and uses the following default registers:
Register 15 - 3B = 59 = 1.1875v <---3D voltage
Register 18 - 35 = 53 = 1.1125v <---2D voltage
Drop it in your rivatuner directory and run it.
Here's what it looks like:
http://i327.photobucket.com/albums/k...ageControl.png
I might play around with the code some more, and add some stuff.. But don't expect too much. I usually get bored and never go back to things lol It's more fun for me trying to get the program to do what I want, rather then using it. I teach myself C# as I figure out stuff.
Disclaimer: Use at your own risk! :p:
Edit: attachment removed, use one below.
Nice work and thankyou for sharing ! :)
Sweaaats it sliderzz has themmmmm
Wow, very quick indeed :)
Although, I don't even use it myself I'll say a big thankyou on behalf of everyone who find this add-on useful.
Thankyou for taking the time to create this and share it with the forum :up:
Since it was me who was "OBSESSED" with the slider idea though, I'll take credit for "HOUNDING" this into creation :p:
Thanks again for your efforts mate, I'm sure a lot of users find it very handy.
On my GTX280 Tri-SLI under 16`c chilled water with D-tek unisinks
Upped my voltage from 1.19 to 1.35v result : from 774/1593/1296 to 810/1647/1296 rock stable no artifacts.
Highest i could get was 820/1701/1296 @ 1.46v but after 10 mins the heat gave shader artifacts.
None the less I'm happy with the extra mhz thanks to this simple mod :D
Doesn't work on the GTX260:(
It's detecting wrong values for stock 2D and 3D voltages with a 4870.
it dont work for me either the fact im doing it wrong or watever with my gtx260-216 will wait... for proper program come out.
GTX 260 it works I can change voltage. But in RT monitor my voltage output never changes even under load.:confused: So no way of finding load voltage??
I'm taking the easy road too. They did say soon, so it's really not that big of a deal. My 280 already does what I need it to do, but the voltage tuner will be nice to get those xtra FPS out of my flight sims. To max out FPS and especially max out the min FPS is always a good thing. :yepp:
Sorry guys, it's not smart enough to figure out what card you guys have. it's only setup for 280 gtx, and the registers i noted up above. I'll try to add the ability to change the registers - but that would make it so you need to know which ones to set them to.
Or if someone wants to give me the default registers for their card, I can just make different versions. That would be a lot easier and quicker.
Would need 2D voltage register, and it's default value.
and same for 3D.
I made some modifications to my GUI. It now lets you input 2D VID addrees, and initial value; and the same for 3D. You change those values before moving sliders (if yours aren't same as my default ones). Once you move the sliders it doesn't read from those fields anymore, but displays the values in volts and hex.
1. change values if needed, as pointed out in top picture
2. adjust sliders, see voltages on right side.
3. hit press Set Voltage button. See changes in rivatuner hardware monitoring.
The background changes colors too, as you move the sliders up and down :D
Eventually I'll make it write your register values to a text file (ini), and then read them back next time you open the GUI - So you don't have to keep changing them everytime (if your registers aren't same as the default ones I have programmed).
Disclaimer: use at your own risk! (i'm programmng n00b lol)
Edit: I just realized that it might not still work for some of your cards. since it uses the I2C bus 3, and that's not changeable via the GUI right now. Can't do it now, gotta get ready for superbowl :p
evga powned by diverge :D
Thanks for info justageek95 as well as to Unwinder, been having fun with RT since years. Seriously sad that some guys dont know how to respect others work. :(
:up: Diverge, you rock!! Instead of constant complaining like few others, took it up as challange and now add-on which may come in handy to others.
Big Thanks to mods as well for keeping the thread moving forward.
Nice one mate, drag it all back up again why don't you.
Respecting peoples work has nothing to do with asking questions.....or complaining. Very little would be accomplished in this world without questions or complaints.
Besides, all this was done with days ago....why are you posting these comments...it's all been said many times before.
I've already stated mulitple times in this thread I accept UNWINDERS reasoning even though I don't agree with him. END OF. I ain't complaining anymore. I didn't slag the guy, I never called him any names...I never swore at him....I didn't shout at him...hound him with PM's etc. All I asked (on a few occasions) was why he wouldn't include this in RT. Where you guys get all this "disrespect" nonsense from is beyond me. You're all drama-queens, lol
Asif making RT gives you 100% immunity from ever being asked a question ever again. "How dare you question UNWINDER". "UNWINDER is teh LEET-ZORZ". "BAN the INQUISITOR he SUXORZ" is all you here from you lot.
Calm down.....accept reality (as in the slider apps been made, no-one is asking for it anymore) and move on. I know it's hard not to run in here and show unwinder how you love him by continually having a dig at me but really all your doing is the same thing you accuse me of.
LET IT GO
besides which, how do you know Diverge woulda made that add-on had it not been for me and my "hounding"? Maybe he got so fed up seeing me ask for it that he thought "bugger it, I'm gonna make the bloodmin' thing just to shut his cake-hole" lol
First, I was outta town... and you cant make me quit reading threads and posting.
Second, You dont know me and this is my first post in this thread. I can surely say what I feel about the situation in a very very public way without abusing. So no need to tell me to calm down. The way you have reacted to my post clearly confirms you as what others mentioned, a whiner!
One more thing, I dont think Diverge ever mentioned he made that add-on because of you. So untill he does that I think it is you who should stop being a drama-queen.
Most important thing of all, better start good work @ home. So I guess you should "Let it go first". But then I am sure all most everyone would expect even more lengthy reply from you. ;)
Signing out. Dont have time to waste :)
Who said to quite posting? Drama perhaps?
Sure, but really there was no need. If you read the thread you read others already tell me off so what need was there for you to bring it up again? YOU wanted to bring it up again. Can you see the sense in that? Some people might call that trolling.Quote:
The way you've reacted? I merely posted a reply. Drama perhaps?Quote:
Can you read my last post? You see the LOL at the end yeah? What age are you? You seem very childish. It was meant in a humorous manner.Quote:
I mean c'mon, please....grow up. Anyone with a pulse and a braincell would know my reference was made jokingly.....you really are trying to make something out of nothing aren't you?Quote:
Do you? Weird, 'cos I coulda sworn I have already. Infact I'm positive I already posted TWICE saying I've LET IT GO already. I'm sure if you scan back the posts you'll see it. Kinda mad telling me to LET IT GO when I already have huh? Infact that's exactly what our conversation is about....the fact I ALREADY LET IT GO and how you've come in draggin' it all back up again!!!:confused:Quote:
That's really great advice mate.....:confused::rolleyes:
STOP with the flame fest you two (mostly KELL5) before I feed you both to the admins
omg this thread is like 30% useful on topic and 70% garbage... hopefully a mod will go pick up the vacuum cleaner and tidy this thing up.
Diverge´s tool works fine :)
It seems that it doesn't work with Vista 64... :rolleyes:
http://img66.imageshack.us/img66/8695/14444007vt0.jpg
