Use the -gpu 0 -gpu 1 flags !
don't forget to disable SLI..
If this answer is still needed :shrug:
XP pro 32 bit here and I've never needed the adaptors
He's right on, but may I add:
-enable second monitor
-extend desktop
-disable sli
-use flags -gpu x -forcegpu nvidia_g80
You should be golden.
