It's been mighty quiet in this thread for the last week.
Here's what I've been working on. :)
http://img512.imageshack.us/img512/2...1httestpu7.png
I did a quick update to the GUI so the buttons, etc. are XP style. The toggle button in the top right corner is a little wider so it should be easier to click on.
The PROCHOT# section seemed to confuse some so I cleaned it up as well. If your processor is running fine it will display OK. If it is presently throttling it will say
HOT and if there was a thermal throttling episode since you started up then it will report that as LOG. I might have to pull the plug on the CPU fan tomorrow to make sure this is working properly! That new IntelBurnTest should get RealTemp lighting up like a Christmas tree.
Edit: IntelBurnTest was causing too many fluctuations in core temperatures so I used Prime small FFTs instead. In the updated pic, core0 is thermal throttling, core1 has thermal throttled but is not currently throttling as shown by the LOG entry and core2 and core3 are still OK and have not done any throttling.
The logging file has been updated to include the date and if you hover the mouse above the Min or Max area it will pop up a date in case you run your computer for days / weeks and can't remember when that happened. Also added a Reset option to the System Tray menu for easier / quicker access.
I'm thinking about allowing users to customize the background and text colors like this which might blend in better with the generally dark Vista themes:
http://img504.imageshack.us/img504/9783/rtdarkzj6.png
Hopefully a beta of all this good stuff will be ready in a few days for some testing. Everyone must be happy because I haven't heard any complaints lately! :D
