Thanks for the credit:),
It bugs me that i cant enjoy my new wc rig because of the pump. Called Aquacomputer and they told me i should expect it next week wednesday:(
2 weeks without my pc......:(
Well done on that white & red themed Lian Li. Down to the window cutouts that match the front of the case... great attention to detail !
anthony8659 where did you get that tag RIG NOOBIES?
Just re-ran my loop, changed the pump position and lots of small changes.
http://i59.photobucket.com/albums/g2...IMG_0020-1.jpg
http://i59.photobucket.com/albums/g2...IMG_0026-2.jpg
http://i59.photobucket.com/albums/g2...IMG_0036-2.jpg
http://i59.photobucket.com/albums/g2...IMG_0034-1.jpg
I've been thinking of sanding the tops of the blocks as well as the fan to give it the same frosted look that the rad shroud has, just dont know yet...
had this happen to an EK res and somehow killed only the PCIe power lines of a PSU
http://i18.photobucket.com/albums/b1...h_stuff045.jpg
so I redid my crappy loop, I think this one came out rather nice
http://i18.photobucket.com/albums/b1...h_DSCN0053.jpg
http://www.shrani.si/t/2/GV/2gD2Uph3/p1030863.jpghttp://www.shrani.si/t/3X/cU/2bgZLhoa/p1030862.jpghttp://www.shrani.si/t/3X/je/4qfDKHQr/p1030861.jpghttp://www.shrani.si/t/40/T0/1pPiHM92/1/p1030850.jpghttp://www.shrani.si/t/2A/2i/3iHB1mi2/p1030864.jpg
Sorry for bad pictures
P.S. How to get air from the tube ?
@ gmat & colossous
Thanks for the kind words
@ illidan
got the tag from our group, actually more of a family of pc enthusiasts here in the Philippines
Mine
From this
please resize image
to this
Res and rad fitted
please resize image
Res, rad and pump fitted with hoses
Please resize image
Loop finished
please resize image
close up of the GPU block
Dont worry I have I put cable ties on the barbs aswell now.
EDIT (by shazza) - Nice job on your build. Please resize photos to a max of 1280 x 1024 pixel (but 1024 x 768 pixel is preferred). Last 2 images deleted as there is a 4 image limit - please feel free to post links or thumbnails if you'd like to show more.
EDIT - 4/23 - Images deleted. Please resize and repost - remembering "4 image limit" (Holler if you need help resizing)
@bitemark
too bad the last pics are blurry... looks clean tho from what i can tell :)
.....I don't think its shazza's job to re size/tidy up stuff (tho she does it.... she shouldn't have to....)
.... not trying to be mean or anything... just pointing it out
[QUOTE=M_T_M;
P.S. How to get air from the tube ?[/QUOTE]
I set the front of my case on a book so it is a few degrees up. It will help the air go towards that direction.
http://img684.imageshack.us/img684/3732/p1060059f.jpg
http://img26.imageshack.us/img26/837/p1060064s.jpg
http://img718.imageshack.us/img718/3866/p1060063.jpg
http://img23.imageshack.us/img23/1452/p1060069f.jpg
http://img709.imageshack.us/img709/9607/p1060072t.jpg
link buildlog: http://www.highflow.nl/forum/f34/vin...ouwput-p-5942/
Nice case i have the same in black. How did you do to have illuminate blue stripes the front ?
Nice looks, but gpu/cf interconnection is .. i wonder what temps such setup for gpu-s brings :D
i mounted a ledstrip in the front these: http://www.highflow.nl/modding/leds/...blue-60cm.html
@vin_tech: Great Job. I might find my next case. Looks like two 360 rad is easy with shoud.
Hi, new here :)
Wanted to show my build too
Somehow it will never be finished :)
specs:
i7 950 @ 4.2 Ghz - Asus P6T6 WS Revolution - 6 Gb Corsair Dominator - Corsair Obsidian 800D - Corsair HX 1000W - Gainward GTX295 - Highpoint 3560 24x sata 2 GB - 2x Intel X25-M 80GB raid0 - 6x Hitachi 2TB raid5
2x D5 @ 1
2x D5 @ 5
My radiator under the floor
http://www.l3p.nl/files/Hardware/Cor...0%5B400%5D.JPG
What deposit is it??
Hi all. Here's my two cents. Not as nice as most on here but she does me fine! Specs below...cheers.
http://i791.photobucket.com/albums/y...g?t=1272137441
Water Cooling XSPC 5.25" Bay Reservoir - XSPC Delta V3 CPU Waterblock - XSPC RX240 Rad - DD-CPX Pro 800 Pump
Specs Core i5 750 @ 4.3GHz - 4GB Corsair Dominator PC3-12800 - EVGA P55 SLI - XFX GTX 260 (216) @ 700.1509.1500 - Corsair HX850 - 8 x Nexus 120mm Fans - Zalman ZM-MFC1 Plus - Modded CM690 Nvidia Edition
