@Ket
That's a much more constructive comment! I was more familiar with standard radioactive dating, my bad. I do agree isochrons methods are much stronger and much better when accounting for contamination, but consistent less than 1% margin is a bold statement even for the scientists who wrote the papers. Proof for me would be a complete survey taking tens of thousands of samples from all continents and major islands, have them analyzed in at least 3 different labs with at least 3 different techniques and have them cross checked. I would not say it's impossible, just I would like to see the proof since this is fully verifiable. If there is one already, please post a link, I'm interested. And there are some concerns about the methodology (
http://creationwiki.org/Isochron_dating ). Overall better, but still susceptible to the core assumption of constant rates. And it does not account for transmutation events that could change the ratios of the stable isotopes. There is a lot of hype around LENR processes these days which are labelled as pseudo-science by many mainstream researchers. I would rather keep an open mind on it.
Anyway, here is a simple hypothesis: the subatomic particles or the arrangement itself could absorb a specific type of energy or could interact with some other unknown subatomic particles that would make the configuration to break in various ways. This energy/particles are currently not detectable with current technology but could be detected with future technology. If this would be the case, then the decay would be constant as long as that form of energy or particle flow is constant. The focus should then be to try to measure and generate this energy/particle flow. If such a hypothesis would come up to be true, it would then explain easily accelerated decays as simple earth/cosmic events. And it would allow for cheap and infinite sources of energy, all while cleaning the nuclear waste that we have. As you can see if such a hypothesis would be found as true, it would not need, nor confirm the existence of God, but would weaken if not destroy the arguments denying a God (like dating methodology on which complete evolution theory stands).
According to the Bible, world was judged before once and destroyed by water. The event was a global one, therefore all world was under water for over one year. As humans are resilient and according to the Bible also advanced at that time, you can assume the event was so violent that no ships or shelters except the ark survived. You need a tremendous amount of energy to move the earth crust and reshape it, and here I think there is room for the earth/cosmic event that could have generated the accelerated decay. The energy release from the accelerated decay could have heated up the oceans, evaporate a huge amount of water that would in turn translate to continuous rains. The energy would have heated the crust underneath to destabilize and make it sink or shift, which would have generated super tsunamis that would have leveled out and rapidly buried marine organism, plants, mammals, dinosaurs and everything that lived on the surface of the earth. The event would have split the original continent and recreated the world we know now with mountains like Everest and so on. The event would have left as evidence a complete earth filled with layers and layers of mud filled with marine and terrestrial life rapidly buried. This would beg the question: are modern, naturalistic scientist able to detect the evidence of a possible global flood using current science knowledge? As long as radioactive dating is seen as a natural phenomena immune to any kind of cosmic event, then answer is no, no matter how strong would be the evidence. Also according to the Bible, there will be a second and last judgement, this time by fire. One of the signs would be the moon getting red which would be quite possible if the judgement will start again with an event that speeds up the decay so much that moon crust will heat up to become red.
