Lian-Li PC05B
Lian-Li PC05B
I feel so embarrassed when I see all these nice clean builds here and look at my own gaming/benching rig :hitself:
My case is so messy I can't even find my mobo in it. :eek:
http://imageshack.com/a/img577/1907/i1gk.jpghttp://imageshack.com/a/img833/5416/l9s8.jpg
Backside are not better :shakes:
http://imageshack.com/a/img202/5831/20la.jpg
Content:
Lian Li PC343B-XT, Rampage IV Extreme, 3960X, 16 GB Corsair Dominator Platinum 2400 MHz, 2x EVGA 780 Ti Classified
Dual-loop water cooling setup: 2x 35x pumps, 4x radds, 16x 2000 rpm fans.
^^^ Now I feel right at home! LOLOL
Jesus, mydog is like my first ever system..
This was my first build back in 2007 not pretty either
http://imageshack.com/a/img856/7787/t0us.jpg
But my second was not to bad
http://imageshack.com/a/img97/5971/xs1x.jpg
Nice colors :rofl:
Switched case and got the tubing and wiring cleaned up a bit
From this
To this
http://imageshack.com/a/img22/4923/3hxx.jpg
^^ Nice! :D
My first finished system in a VERY long time. Forever Alone Fortress 02 Server Edition.
http://i18.photobucket.com/albums/b1...erverFT021.jpg
http://i18.photobucket.com/albums/b1...erverFT023.jpg
http://i18.photobucket.com/albums/b1...erverFT022.jpg
http://i18.photobucket.com/albums/b1...erverFT025.jpg
http://i18.photobucket.com/albums/b1...erverFT026.jpg
Magnificient!
This is my build here with Corsair Obsidian 450D
https://farm8.staticflickr.com/7406/...930aae8e_c.jpg
https://farm8.staticflickr.com/7403/...c6e5e259_c.jpg
Excuse the ghetto rigged bench on the left. One day I will finish my PC and it will take its place. :p:
http://i18.photobucket.com/albums/b1.../export-28.jpg
New build.
i7 2700k @ 4ghz 1.1v + Thermalright HR-22 fanless
GTX750Ti (msi gaming) stock + Xigmatek Bifrost fanless
RM750 psu - fan never turns on
Temperatures depend on ambient, but usually in normal use cpu load: ~60, gpu ~65.
All pics: https://picasaweb.google.com/1040301...chMiniFanless#
Few selected pics:
https://lh4.googleusercontent.com/-e.../001_dimas.jpg
https://lh4.googleusercontent.com/-b...dimasfinal.jpg
https://lh6.googleusercontent.com/-2.../019_dimas.jpg
https://lh6.googleusercontent.com/-5.../029_dimas.jpg
https://lh3.googleusercontent.com/-Q.../036_dimas.jpg
Great looking cases
I just did a system refresh and put in some upgrades.
System Specs:
NZXT Switch 810 Matte Black
Corsair AX750
EVGA X58 FTW3
Xeon L5640 @ 3.4
24gb (6x4) Corsair Dominator
MSI R7970 3gb
2 256gb Samsung SSD Raid 0
300gb WD VR scratch drive
Cooling:
HK 3.0 LT
EK 7970
Switech MCR 360, 240, 120
Corsair SP120 in push/pull wired at 5v
Hidden XSPC dual res with D5 vario
Enzotech rotaries with 7/16 tubing, no clamps, heat shrinked connections.
I'll still be changing some little things but overall I am happy with it.
http://i37.photobucket.com/albums/e9...psc013667e.jpg
http://i37.photobucket.com/albums/e9...ps47ff5c2f.jpg
http://i37.photobucket.com/albums/e9...ps8f4d1d79.jpg
http://i37.photobucket.com/albums/e9...ps70bd9397.jpg
http://i37.photobucket.com/albums/e9...ps3a8e6abc.jpg
Very nice job!!
This is my HR GIGER Tribute PC. It actually started this build a few years ago, but got shelved so I could take on customer commitments, so it has a mixture of old and new hardware, what prompted me to finally get it done, was HR GIGER's Passing on May 12, 2014, and the recent mod zoo "dust-off" event. If you've never of HR GIGER, he was most well known for his Visual Effects and design work on the first Alien movie, and of course the iconic Xenomorph ALIEN, long before working on that movie, he had established career as a painter, and had a very distinctive style that blended human bodies and machines that he described as "Biomechanical" ...which inspired the look of this PC..... the hardware as I said, is combination of old and new... the chassis is a Cooler Master 912 turned 90 degrees, and it's been 3 years since the asus sabertooth TUF shield was airbrushed with the Giger theme, the system has two seperate liquid loops, the stainless tube reservoir is for the GPU loop, and has Hardware Labs Black Ice 360 GTX, cooled with Panaflo L1As, these are 38mm thick, 68.9 CFM. Max. noise: 30.0 dB-A, the grill is from Mnpctech.com, with D5 pump and Alphacool top, the CPU is 3570, 3.4 GHz, with Swiftech's new Apogee XL waterblock, this a great waterblock for $69, and it comes with interchangable illuminated faceplate, my good friend EEL Ambiense designed a new replacement faceplate with a Giger-esque design, which I had laser cut, the cpu loop is PETG hardline tubing with EK 190 & DDC res / pump combo. Both loops are running distilled water. The system utilizes 32GB of their ADATA's new XPG V2 DDR3, and their Premirer Pro SP920 256GB SSD... I'll be using this PC in the shop for video editing primarily, so these two AMD Radeon 270Xs in Crossfire will save me from waiting for video to render all day... they're cooled with copper GPU blocks by Syscooling, just because I couldn't help myself...lol, and the power supply is a Corsair 750.
You can see how I created this PC here, http://mnpctech.com/cooler-master-ca...echanical.html
https://mnpctech.com/images/companie...r_lo_res_8.jpg
https://mnpctech.com/images/companie..._hi_res_9e.jpg
https://mnpctech.com/images/companie...r_swiftech.jpg
https://mnpctech.com/images/companie..._hi_res_9j.jpg
https://mnpctech.com/images/companie...r_lo_res_4.jpg
Thank's Bill Owen for sharing H.R. Giger's nightmares, You are skillfull as always:)
This must be my final build and no sloppy compromises this time!
I stuffed a ASUS Server motherboard + GeForce Titan Z in the Silverstone Raven03 case.
Parts used:
ASUS Z9PE-D8 WS.
Dual Intel XEON E5-2630V2.
8x4GB Corsair VengeanceLP 1600MHz CL8 DDR3 RAM.
Corsair AX860 PSU with sleeve kit.
ASUS GeForce GTX Titan Z.
Soundblaster Recon3D FC.
LSI 9207-8i HBA, SAS2 controller.
Samsung EVO840 Basic 750GB.
2x Seagate Cheetah 15K7 600GB SAS HDD's.
HP Storagework Ultrium3 920.
Pictures>
Raven1:
http://i1153.photobucket.com/albums/...ps3b0e6be4.jpg
Raven2:
http://i1153.photobucket.com/albums/...psa833f62f.jpg
Raven booted without problem but Win8.1 Pro didn't find the SSD drive, next try it did.
Haven't touched BIOS yet because the PC doesn't react to DEL or F2 at POST.
http://omniserver.pl/4ddd5/2013/LG%20AIO/new%20old.JPG
LEFT
GA-H81TN
G3220
2x2gb 1333
256gb liteon msata ssd
LG 23EA63V IPS
120W powerbrick for pc and lcd
total power consumption 45-50W
temps 50-55, max 65-70*C
RIGHT
G2020 + thermaltake x3 slim
INTEL DH61AGL
2x2gb 1333
vertex2 200gb sata2
LG 23EA63V IPS
90W powerbrick for pc and lcd
total power 43-48W
http://omniserver.pl/4ddd5/2014/htpc...ezba%20end.JPG
http://omniserver.pl/4ddd5/2014/htpc...l/xx%20end.JPG
also HTPC
G2020
GA-H77TN
2x2gb 1333
agility3 60gb
60W powerbrick
HUSH ITX PASSIVE CASE
LG 55" 55LE7900
No more new update???????????
think site maintenance set us back to 2014
