2x16 Gb Micron E-Die at 1.52v
?150 for 2x16 Gb rated for 3200 Mhz 16-18-18 1.35v:
https://i.imgur.com/2iyaEHw.png
Ballistix LT Sport. This kit was bought before they started separately binning 3600+ Mhz kits, so if you wanted similar you would need to buy at least a 3600 kit now.
I may have been the first person to push a 2x16 Gb to 4000 Mhz back when I bought it - it did 4000 Mhz CL18 1.48v on Z390, currently doing 4133 CL16 1.5125v on Z490.
My kit also does stock timings and volts 3600 easy, and 3600-3800 CL14 at 1.4v+.
4133 CL17 needs just 1.425v.
4200+ is a no go on my modules, even 4266 CL18 wont get stable, most likely limited because its 2x16 Gb, 2x8 Gb would do a lot more.
I've already corrupted at least 5 windows installs trying to push it higher up to 1.55v or with tighter secondary timings, it wont do much better with 24/7 stability.
