Check/Set your Display DPI to 96. Control Panel>Appearance and Personalization>Display>Smaller - 100%(default)
FELIX, I've started testing Asus P6T6 WS Revolution and seems with 21x turbo multi enabled, CPU Tweaker is SOMETIMES not all the time reporting 0mhz for frequencies. See screenshot below. I've included cpuz 1.51 dump here.
http://fileshosts.com/intel/Asus/P6T..._900_15988.png
I also have that problem intermittently on my P6T Dlx. and from time to time the cpu multi will read one higher as well, using 965XE.
I tried to fix it in this version: CPU-Tweaker 1.2
Also I add 2 timings: "B2B CAS delay" and "Idle Cycle limit" on Core i7 CPU.
Let me know if frequency is not correctly read...
I have that problem too. It happens when some small info and tweak tools are running, not sure. But I'm sure that it always happens when Opera 10 is running. :confused: When I close Opera, CPU-Tweaker starts showing speeds.
Just tried final ver 1.2 and it's not working, most of the times. One time it showed wrong bclk of 207.7, when it was 200.
thank, nice info :up:
Two new beta version:
# memset 4.1 beta4 :- Add support for Intel Core i3 & i5 (Clarkdale) CPUs.
Memory Configuration space -mchbar- is exactly the same as P45 chipset
(probably in the IGP include on the same package) this is why I use memset for this CPU.
# CPU-Tweaker 1.3 beta1: -Add support for Intel Core i5 & i7 (Lynnfield) CPUs.
It seem that PCI configuration space (same as Core i7 Bloomfield) is unlocked on this CPU...
Thank at Chri$ch for his help and tests. ;)
:up::up: Great update thanks felix :D
Hi Felix. Memset 4.1B4 has a weird bug. This is how it opens after clicking exe.
- If I set PL in column B and save then reopen it, it defaults back to this.
- When I completely removed all traces of memset and reload it, I still get the same results :shrug:
Memset 4 works fine :up:
Running Windows 7 RTM x64
http://img2.imageshack.us/img2/6212/memsetbug1.jpg
=>gymenii: corrected in this version.
=>3oh6: could you make a registers dump (with cpuz->last table->registers.txt)
and send it at memset@hotmail.fr
Thank...
Fixed!
Mille fois merci
Hi, FELIX!
Thanks for this great work...
Well, I have a problem:
DDR2 Memory frequency dosn't work for my two computers, there are only showed as 0.0 MHz!
One computer have 1000 MHz real DDR2 frequency, and hardware configuration is:
- Gigabyte GA-EP35-DS3 (rev. 2.1, BIOS ver. F3)
- Intel E8300 Core 2 Duo 2.83 GHz (overclocked: 3.50 HHz)
- Kingston HyperX KHX8500D2/2G (2x2GB)
Cumputer is overclocked!
Second one working on the 667 MHz DDR2 frequency, configuration is:
- MSI P45 Neo
- Intel E2200 (2.20 GHz)
- Kingston ValueRAM
Computer iz NOT overclocked!
Where is the problem here???
Also, on both computers I can't change "CAS# Latency (tCL)" and "Command Rate (CR)", while
all other timings are configurable from MemTest!?
Why is that happend?
Thanks in advance!
Kind regards,
Stole
X58 does not work on Asus REX II on XP. There is no approval of the amendment ??
http://images47.fotosik.pl/193/5ea61cd72e9598f8m.jpg
A new beta version: CPU-Tweaker beta8
Not Found
The requested URL /download/CPU-Tweaker12b8.zip was not found on this server.
and CPU-Tweaker ---MC_CFG_space_Locked
thanks Herve,
tested on 2 Boards, but can change only on Asus the timings ;)
http://www.abload.de/img/cpu-tweakerszox.png
http://img1.abload.de/img/b2b-3o3r0.jpg
http://img1.abload.de/img/b2b-193il.jpg
=> StoleJova: is memset 4.0 read the memory frequency correctly?
For "CAS# Latency (tCL)" and "Command Rate (CR)", is not possible to change these timings under Win.
=> marcin255: Is not possible to change timings with memset on NHM; with CPU-Tweaker,
it's possible with GygaByte, eVGA ,DFI and Biostar motherboards.
(Memory Configuration space are locked in the bios on others motherboards)
Last beta version is CPU-Tweaker13b1.zip
=> Chri$ch: Like Core i7 Bloomfield, Memory Configuration space will probably locked
on some motherboards with lynnfield.The great news is Asus was decided to unlock it.
Could you make a registers dump of the other board (with cpuz->last table->registers.txt)
Thank.
=> 3oh6: Just got your mail, thank. I let you know when the problem will be fixed.
...you can always send an email to Asus engeeners, but it's already do.
No, neither 4.0, or any other version can't read RAM frequency correctly on my computer... :(
Well, I don't know that, thanks!
It's little confusing, options are enabled, combobox is working, but can't select anything - so I thought that something was wrong... Maybe it would be nice if that two options will be grayed and disabled (just suggestion)?!
Thanks for response!
Felix,
I see some BIOS allow enable or at least showing DIMM interleave aswell as RANK.
I would like to see this, on my output, so I can :banana::banana::banana::banana::banana: if the BIOS not smart enough to enable it.
if rank > 1 on DIMM, show Rank interleave en/dis., if paired DIMMs show DIMM interleave en/dis.
thx
In someone working on Asus Rampage Extreme II?
