DimasTech EasyGo Fasteners
Finally after a long period of developing, we arrived to the final revision of the Fastener that will help Users of BenchTable on easy Swapping Motherboards and to reduce the use of external HandTools.
The new Support EasyGo Fastener, at the beginning used for PCBs or electronic use have been reinterpreted for the use on motherboards, this support on the other hand is still possible to be used in electronic/PCB use.
The Fastener is connected to the benchtable via a M3 Male Thread
The product actually sell at 5,99€
DIRECT LINK TO THE DIMASTECH SHOP -> EASYGO FASTENERS
Images:
http://www.dimastech.it/Img/Prodotti/3808/6044_zoom.jpg
http://www.dimastech.it/Img/Prodotti/3808/6050_zoom.jpg
http://www.dimastech.it/Img/Prodotti/3808/6047_zoom.jpg
abstract from description:
New DimasTech® Spacers was born from the need to make it more fast assembly and disassembly of the Motherboard on DimasTech® Bench/Test Tables.
Technical Specifications:
Material: Zinc Steel
Height from Plan of the Bench/Test Tables: 25mm
Diameter: 6mm
*M3 Male Thread
Compatibility:
Applicable to All DimasTech®Bench/Test Tables from Version V1.4 to V2.5 for all the latest Models:
Easy
Hard
Easy Hard
Package:
10 DimasTech® EasyGo Fastener supplied in a convenient reclosable blister
Note:
The DimasTech® Bench/Test Table present in the photographs is not included, so that will be purchased separately.
