GPU-Z 1.20.0 (April 18th, 2017)
https://www.techpowerup.com/download/techpowerup-gpu-z/
- Fixed BIOS extraction resulting in corrupted BIOS on Radeon RX 500 Series
GPU-Z v2.0.0 (May 23rd, 2017)
- Advanced Tab added, with additional on info on VGA BIOS, CUDA, OpenCL, DirectX, Vulkan
- Added support for EVGA iCX Sensors
- Fixed BIOS saving on GeForce 900 Series and newer, on 32-bit OS
- NVIDIA PerfCap Reason "Util" renamed to "Idle"
- Added retry option to "Rendering doesn't work over remote desktop" message
- When log file can't be written to, stop trying until re-enabled by user
- Fixed DirectX Support detection on old ATI cards (R600 and older)
- Added support for NVIDIA Tesla P100 PCIe, Tesla M10, Quadro P5000
- Added support for Intel Graphics 615
- Added support for AMD HD 8350G
GPU-Z v2.1.0 (May 23rd, 2017)
- Various bugfixes
GPU-Z v2.2.0 (July 6th, 2017)
- Added AMD Radeon memory timings section to Advanced Tab
- Added driver date to driver version tooltip and to Advanced Tab
- Added settings entry to set sensor default display mode (cur, min, max, avg)
- Added right-click menu to Advanced Tab to copy to clipboard
- Improved GPU-Z startup speed, especially on slow or single-core systems
- Query_External files will be deleted from temp folder immediately
- Fixed order of OpenCL entries in Advanced Tab (CMD Queue Properties)
- Fixed missing sensors in shared memory
- Fixed display corruption on older NVIDIA GPUs
- Added EVGA iCX fan monitoring support
- Added die size and transistor count for AMD RX 560
- Added support for Intel Iris Plus 640 & 650, GMA600
- Added support for NVIDIA GeForce GT 1030, GeForce 810M, Mining P104 & P106, Quadro P3000
GPU-Z v2.3.0 (September 5th, 2017)
- Added support for AMD Radeon RX Vega Series
- Fixed incorrect/missing information AMD Catalyst 17.2.2 and newer
- Fixed GPU & memory activity monitoring on AMD Radeon RX 500 Series
- Fixed crash on startup in rare CrossFire configurations
- Fixed CrossFire detection for slave cards
- Addded VRM efficiency & VDDC/VDDCI power readings for Polaris
- Added support for AMD Radeon WX 7100, WX 3100
- Addded support for NVIDIA Quadro M2200, GTX 1080 Mobile, GeForce MX150
GPU-Z v2.4.0 (September 7th, 2017)
- Fixed AMD RX Vega shader count detection
- Fixed OpenCl detection on ATI/AMD cards with older drivers
GPU-Z v2.5.0 (November 6th, 2017)
Release notes:
- Added driver date and WHQL status as separate items
- Added refresh button
- NVIDIA BIOS version is now always uppercased
- Renamed "ForceWare" in driver version to "NVIDIA"
- Updated NVIDIA NVFlash for BIOS saving
- Added support for NVIDIA GTX 1070 Ti, GTX 1050 Ti Mobile (GP106), NVIDIA Quadro GP100, Quadro M620
- Added support for Intel UHD Graphics 620
- Added support for AMD RX Vega 64 Liquid, FirePro M4150
- Added Vega SOC Clock, VR SOC and VR Mem monitoring
- Added support for WDDM 2.3
- Fixed GPU-Z crash when trying to display error message for failed BIOS upload
GPU-Z v2.6.0 (January 16th, 2018)
Release notes:
- Sensor refresh will no longer lag the GPU-Z window
- Fixed GPU-Z not starting at all due to broken UPX EXE compressor
- Fixed crashes on RX Vega
- Fixed fan RPM monitoring on RX Vega
- Added support for Radeon Adrenalin Edition
- RX560 GPU renamed from Baffin to Polaris 21 at AMD's request
- Added support for NVIDIA Titan V, GeForce GTX 1060 5 GB, Tesla K40m, GeForce 825M, Quadro M520, NVIDIA NVS 810, NVIDIA Grid M6-8Q
- Added support for AMD Vega 8 Raven Ridge Graphics, Pro WX 9100
- Added support for Intel HD Graphics P630, UHD Graphics 630, Gemini Lake UHD Graphics 600
- Fixed GP100 die size
- Fixed Braswell 16 vs 12 EU count
- Fixed crash on AMD cards with empty board Id (MSI RX 580 Armor)
GPU-Z v2.7.0 (January 23rd, 2018)
Release notes:
- GPU-Z will no longer block Windows shutdown/restart on Fall Creators Update
- Updated NVFlash for newer NVIDIA cards like GTX 1070 Ti
- Fixed reported VRAM size on Vega (now 8192 MB)
- Fixed incorrect labelling of GPU Memory Clock Sensor on NVIDIA
- Fixed Polaris 21 OpenCL and TMU/ROP detection
GPU-Z vv2.8.0 (February 23rd, 2018)
Release notes:
- Fixed crashes and other issues on AMD Ryzen Raven Ridge APU
- Added DXVA 2.0 hardware decoder info to Advanced Tab
- "Disable sensor" menu item now properly called "Hide"
- Improved VRAM usage monitoring on AMD
- Improved rendering performance of NVIDIA PerfCap sensor
- Improved AMD power limit reporting in Advanced Panel
- "MemVendor" is now included in XML dump output
- Fixed NVIDIA PerfCap sensor drawing outside its area
- Fixed "BIOS reading not supported" error on NVIDIA, on some motherboards
- Fixed HBM memory type detection in Advanced Tab on Fury X
- Fixed temperature misreadings on Vega
- Fixed "Digital Signature" label getting truncated on some hidpi screens
- Added support for RX 460 Mobile, RX 560 Mobile, RX 570 Mobile, RX 580 Mobile, RX 550 based on Baffin LE
GPU-Z v2.9.0 (May 7th, 2018)
Release notes:
- Fixed empty or incorrect readings for NVIDIA GPUs in TCC mode (Quadro/Tesla)
- Added WDDM 2.4 support for Windows 10 RS4 / April Update / Spring Creators Update
- Added support for NVIDIA Tesla V100
- Added support for Haswell GT1 in Celeron 2961Y
- Added support for HBM2 memory type in Advanced Panel, NVIDIA BIOS
- Added support for perf cap reason 'none' (Tesla in TCC mode)
- Added more Bristol Ridge models
- Fixed detection for AMD Carrizo/Bristol/Stoney
- Changed Wani name to Carrizo/Bristol
- Fixed DirectX support reporting for ATI RV200
- Vega's SOC Clock and Hot Spot sensors are now disabled by default at request of AMD. You can enable them any time in settings
- When GPU-Z is set to launch on Window startup, disable "This file was downloaded from Internet" message
- Fixed top right button corruption when resizing the window
- Improved drawing code for sensor graph
GPU-Z v2.10.0 (July 19th, 2018)
Release notes:
- Added CPU temperature monitoring for Intel Sandy Bridge and newer and all AMD Ryzen
- Optimized sensor graph drawing code for faster repaint with lower CPU usage
- Various improvements to avoid error messages related to Query External
- Added button to reset sensor data
- Fixed missing tooltip for GPU clock sensor
- Report Overdrive Limits in Advanced: ATI/AMD BIOS
- Added GDDR6 memory type
- Delay "Screenshot taken" dialog by a second, to not get captured by screenshot
- Fixed secondary devices showing up with no info (old ATI cards)
- Fixed memory clocks on Intel Arrandale
- Fixed memory module info in Advanced Panel for AMD Vega
- Added support for AMD Vega M GH, Vega M GL, WX 4130, WX 4150, WX 8100, Radeon Pro Vega 56, Pro SSG
- Added support for AMD Vega Graphics in Ryzen 3 2200U, Ryzen 3 2300U, Ryzen 3 Pro 2200GE, Ryzen 5 2400GE, Ryzen 7 2400U
- Added support for Intel UHD 605, UHD 610, UHD 630, P580
- Added support for NVIDIA GeForce GTX 1060 6 GB, GTX 1050 3 GB, GTX 1050 2 GB (GP106), GTX 1050 Ti Max-Q, MX110, MX130, GTX 750 Ti (GM107B)
- Added support for NVIDIA Quadro GV100, P600 Mobile, P620, P2000, P3200, P4200, Grid M3-3020
- Added support for NVIDIA Tesla V100, V100-PCIE-32GB, M4, P106-090, P5200, P6, P40, P100 SXM2, P100 PCIe 12 GB
GPU-Z v2.11.0 (September 17th, 2018)
Release notes:
- Added NVIDIA GeForce RTX Turing support
- Added option to minimize GPU-Z on close
- Added system RAM memory usage sensor
- Added temperature monitoring offset for Threadripper 2nd gen
- Fixed typo in NVIDIA Perf Cap Reason tooltip
- GPU-Z will no longer use AMD ADL memory sensors because they are buggy, WDDM monitoring used again
- GPU Lookup feature improved by taking boost clock into account
- Added ability to clean up old QueryExternal files in temp directory
- Added support to BIOS parser for USB-C output, GDDR6 memory, 16 Gbit memory chips
- Added support for NVIDIA RTX 2080 Ti, RTX 2080, RTX 2070, GTX 750 Ti (GM107-A), GTX 1050 Ti Mobile 4 GB, Quadro P1000, Tesla P100 DGXS, GeForce 9200
- Added support for AMD Vega 20, Fenghuang, Ryzen 5 Pro 2500U, 5 Pro 2400G, 3 Pro 2200G, 3 Pro 2300U, 3 2200GE, Athlon 200GE, Embedded V1807B
- Added support for Intel UHD 610, UHD P630 (Xeon), Coffee Lake GT3e (i5-8259U)
GPU-Z v.2.12.0 (October 12th, 2018)
Release notes:
- Added detection for fake graphics cards using old relabeled NVIDIA GPUs (G84, G86, G92, G94, G96, GT215, GT216, GT218, GF108, GF106, GF114, GF116, GF119, GK106)
- Added BIOS saving capability for NVIDIA Turing
- Added monitoring for multiple fans on Turing
- Added fan speed % monitoring on Turing
- Added HDMI and DisplayPort info to Advanced -> NVIDIA
- Power draw on NVIDIA cards is now reported in both TDP % and Watt
- Fixed system hang caused by Valve anti-cheat
- Fixed memory bandwidth on Turing with GDDR6
- Fixed tooltip for system memory usage sensor
- Fixed broken Radeon RX 400 GPU usage monitoring on newer drivers
GPU-Z v.2.13.0 (October 15th, 2018)
Release notes:
- Fixed missing fan speed sensors for pre-Turing cards using GeForce driver 400 and newer
- Fixed some rare crashes during GPU-Z startup
- Minimize on close will now trigger on "Close" button click, Escape key, ALT+F4. Use the tray icon menu to exit GPU-Z when "minimize on close" is enabled.
- Screenshot button tooltip will no longer be visible in screenshots
GPU-Z v.2.14.0 (October 25th, 2018)
Release notes:
When available, boost clock is used to calculate fillrate and texture rate
Fixed missing Intel GPU temperature sensor
Fixed wrong clocks on some Intel IGP systems ("12750 MHz")
NVIDIA power sensors now labeled with "W" and "%"
Added support for Intel Coffee Lake Refresh
GPU-Z v.2.15.0 (November 15th, 2018)
Release notes:
Added hardware giveaway (to the left of "close" button): 2x PowerColor Radeon RX 590 Red Devil, 2x AMD Ryzen 2600X, 15x $30 Steam coupon
Fixed Quadro K4000 and K2100M detected as fake
Added support for AMD Radeon RX 590
Added support for Intel Whiskey Lake, UHD Graphics 617 (Macbook Air 2018)
Added support for NVIDIA Tesla V100-SXM2-32GB
Fixed Vega 20 release date
GPU-Z v.2.15.0 (December 10th, 2018)
When a UWD/DCH driver is detected on Windows 10, it will be displayed as "DCH" in driver version
Advanced tab now includes an entry showing DCH driver status on Windows 10
Added EVGA iCX support for RTX 2080 FTW3 and RTX 2080 Ti FTW3
Fixed GPU-Z crash on AMD Polaris
Added support for NVIDIA GeForce RTX 2060
Splash screen is now DPI aware
Fixed sensor list not fully visible on some DPI settings
Fixed rendering artifacts when resizing sensor window
Moved "check for updates" setting to main settings panel
GPU-Z v.2.17.0 (February 27th, 2019)
Added support for NVIDIA GTX 1660 Ti, Titan RTX, RTX 2080 Mobile, RTX 2070 Mobile, RTX 2060 Mobile, Quadro RTX 4000, GTX 650 (GK106), Quadro P5200
Added support for AMD Radeon VII, Radeon HD 8400E
Added support for Intel Amber Lake GT2 (Core i7-8500Y)
Added support for detection of Radeon Adrenalin 2019 version
Simplified some sensor titles: "GPU Clock", "Memory Clock", "Shader Clock"
Unified "Memory Used" / "Memory Usage" sensor titles to "Memory Used"
Improved crash reporter to ask for problem description and optional email, so we can follow up
Advanced Panel dropdown will show "Memory Timings" option only when memory timing details are available
OpenCL "Max Packet Size" is now formatted as unsigned value
Instead of empty value show "None" when no OpenCL Built-in Kernels supported
Added support for "None" in OpenCL DP, SP, Half FP Capability
Fixed "File creation failed" message during GPU-Z startup
Fixed GPU and memory load monitoring on RX 580 2048 SP
Fixed missing default boost clock on GTX 1660 Ti and some Pascal cards
Fixed missing fan sensors on RTX cards with no monitor connected
Fixed crash on startup (Windows XP)
Fixed crash when opening DXVA 2.0 report (Windows XP)
Fixed power limit reporting on older NVIDIA cards
Fixed crash during BIOS save on older NVIDIA cards
Fixed incorrect VRAM reporting on 16 GB Vega
Fixed various crashes caused by physical memory access
GPU-Z v.2.18.0 (March 15th, 2019)
Added support for NVIDIA GeForce GTX 1660, RTX 2060 Mobile (TU106-B), Quadro RTX 5000, Quadro RTX 6000
Added Hotspot temperature monitoring for AMD Radeon VII
Vega 10 & Vega 20 Hotspot no longer disabled by default
Updated PCI vendor database to add new companies and remove unused entries
Ensure "Sapphire" vendor name doesn't get displayed on PCPartner OEM cards
Fixed crash on startup during BIOS parsing on older NVIDIA cards (GeForce 500)
Fixed GPU-Z hang during splash screen on some systems
Fixed system crash on some AMD systems during BIOS read
GPU-Z v.2.19.0 (April 29th, 2019)
Added support for AMD Ryzen 3000 Picasso APUs
Added support for NVIDIA GeForce GTX 1650, GTX 1650 Mobile, GTX 1660 Ti Mobile,
GeForce MX250, TU117-B
Added GeForce MX230 and GP108 transistor count
AMD Radeon Pro graphics cards now show the appropriate logo
Improved EVGA iCX to work better and more reliably detect sensor capabilities
Added support to detect DirectX Raytracing, Variable Rate Shading, WDDM 2.6 and Shader Model 6.5 (listed in Advanced panel)
Advanced Panel now lists new DX12 capabilities introduced in Windows 10 Updates
October 2018 and May 2019
Advanced Panel can now detect Tiled Resources Tier 4
"ASIC Quality" in Advanced Panel will only be displayed when available, since the feature probably won't be coming back for new GPUs
Reduced startup time on system with AMD PowerXpress
Added new icons for the ASUS ROG version and fixed white line below window title
Fixed crash when no cards detected and hovering over driver info
Fixed crash on startup on Windows XP machines
NVIDIA Tesla K80 is GK210, not GK110
GPU-Z v.2.20.0 (April 30th, 2019)
Fixed overclock getting reset on NVIDIA cards with Boost
Fixed crash on Pascal GPUs when no driver loaded
Fixed crashes on Apple Vega 12
Changed memory bus width capitalization from "Bit" to "bit"
GPU-Z v.2.21.0 (May 24th, 2019)
Fixed missing sensor data on AMD Radeon VII with 19.5.1 drivers
Fixed broken GPU load sensor on AMD Raven Ridge APUs
Fix OpenCL detection for Radeon VII and other Vega 20 cards
Added support for NVIDIA Quadro P500
GPU-Z v.2.22.0 (July 1st, 2019)
Added preliminary Radeon RX 5700 & 5700 XT (Navi) support
If a file "GPU-Z.ini" exists in the GPU-Z directory, GPU-Z will use it to read/write all configuration settings instead of the registry, making GPU-Z fully portable
When an unknown GPU is detected, GPU-Z will show a notice window, which requests a validation submission
Addded support for PCI-Express Gen 4
Added support for NVIDIA RTX 2060 Super, RTX 2070 Super, RTX 2080 Super, Tesla T4, Quadro T2000 Mobile
Added support for AMD FirePro S7150, ATI FireStream 9250
Added support for Intel HD Graphics 620
Added AMD SOC Temperature Sensor
GPU-Z v.2.23.0 (August 6th, 2019)
Improved AMD Navi Radeon RX 5700 Series support
Added support for additional variants of RTX 2060 & RTX 2070 Super
Updated icon and splash screen with high-DPI support
Added BIOS saving support for NVIDIA Super cards
Fixed PCIe speed always getting reported as "4.0" on Navi
Fixed crashes caused by Valve Anticheat
Fixed crashes on Radeon R9 290 / 390 Series
Added support for NVIDIA GeForce GTX 1650 Mobile, GTX 1050 Mobile, GT 1030 (GK107), MX150 (GP107), MX250, Tesla V100-SXM2-16GB, Quadro RTX 5000 Mobile, Quadro RTX 3000
Added support for AMD Radeon 550X, Radeon 540X, Pro WX 2100, Pro Vega 64, Pro Vega 64X, Pro WX Vega M GL
Added support for Intel Iris Pro P580, UHD P630, UHD 610 (CFL GT1)
Added support for ATI Radeon HD 4350 (VisionTek)
Gainward vendor Id no longer reported as "CardExpert"
Hardened security of kernel mode driver (CVE-2019-7245)
When log file can't be written, show error message only once
Remove readonly attribute from temporary files before trying to delete
Fixed year in About dialog
GPU-Z v.2.24.0 (August 13th, 2019)
Fixed digital signature error on startup on Windows Vista
Added support for NVIDIA GeForce 305M, Quadro P620
Added support for Intel HD Graphics (Xeon E3-1265L V2)
Fixed some typos in Advanced -> Vulkan
Added Dataland PCI Vendor ID
