PC-Q01 Mini-ITX Prototype - Give Us Your Feedback
Hey guys,
Thanks everyone for your input on the PC-Q33 chassis, if you still have some ideas or feedback for that please feel free to do so.
We do have another aluminum ITX case we are working on, and we would love to hear your feedback on this one too. Tell us what you like and/or dislike as well as ideas you have. On to the case...
The chassis, PC-Q01, has a fully aluminum construction, and is designed to be an small office PC and/or light gaming rig. It comes from the same line of design as the PC-Q07. What the PC-Q01 adds is more space for hardware compatibility (holding up to two 3.5" and two 2.5" drives as well as double slotted graphics card up 210mm), and a L-shaped removable cover that makes installations much easier in space confined ITX systems.
The PC-Q01 is mostly tool-less (featuring thumbscrews) as is designed to be either passively cooled or to have a 120mm or 140mm fan to be placed on the cage floor.
To give you a reference for size the PC-Q01 is about 13.3L.
Below are some pictures for you to get an idea of the case. Take a look and let us know what you think.
Removable L-shaped cover
http://i.imgur.com/1k81Upx.jpg
PC-Q01 with the panel off
http://i.imgur.com/42QtheY.jpg
http://i.imgur.com/uusVegB.jpg
http://i.imgur.com/1YWONEZ.jpg
http://i.imgur.com/b5TIDoc.jpg
http://i.imgur.com/KcLGqMx.jpg
http://i.imgur.com/9tup84L.jpg
http://i.imgur.com/91OPUBt.jpg
http://i.imgur.com/19yeiPc.jpg
http://i.imgur.com/vC2hUj8.jpg
http://i.imgur.com/h0u0Ybq.jpg
Front panel HDD mounts
http://i.imgur.com/vrbomCP.jpg
Scratch-free 3.5" and 2.5" drives mounted behind the front panel
http://i.imgur.com/rshsG19.jpg
More scratch-free hard drives mounted to the case floor
http://i.imgur.com/3LkssAL.jpg
Fan mounted to the case floor (Taking the spot of the bottom HDDs)
http://i.imgur.com/jLRx56W.jpg
http://i.imgur.com/XgZHic7.jpg
Specs
http://i.imgur.com/Tu0Xpzj.png
