Monsoon Series Two DDC
Anyone know if you can use a Swiftech MCP50X pump in a Monsoon Series Two DDC bay reservoir? My MCP35X pump died and I would rather switch to a MCP50X if I can. I would even go with a D5, but I know that design is completely different and I like the reservoir so I do not want to replace it.
lang makes the ddc, it does not matter what case you buy they are all the same. alpha cool even sells bare pumps so you can just replace electronics in your old pump.
IIRC They are all dimensionaly the same, only impeller & controller boards are different. Tops might be slightly different as well? That said they should all be interchangeable...
