The power switch works erratically and doesn?t always click, so you don?t know if it turned on until you hear fan noise. On closer examination, the switch?s pc-board looks partially melted around the solder points, photo attached.
Attachment 131381
Also, the left-side cover fits very poorly, photos attached. The case is very straight, I put it on a flat surface and there is no wobble. But the cover seems to have a slight bend on one end.
Attachment 131382
left-side poor fit
Attachment 131383
right-side ok
I didn?t notice the problem until after the PC was fully assembled, so I?m reluctant to return it because the next one might have the same problem. Can you help?
