http://hwbot.org/submission/2362846_
Booooooom
Booooooom
Someone trade my 4 480s for one of these lol
Yes everything is set to 120 but it never gets there 108 max then it clocks down then up then down.
In the areas of 3d11(first two tests) i notice the throttling most, i read live voltage during those two tests and when it down clocks voltage goes to 1.02 then back up to 1.22v if i have the added .37mv thats when it down clocks??
It also down clocks/volts even if i dont have the added .37mv in those areas.
I wonder if there is someplace else in the voltage table that needs to get adjusted for full 1.22+v all the time.
I really need a spot or two to mod so the dang card dont even see the power limit no more and just be done with it,then we can move on to other mods...right?
May be total board power limit of 108. I look in the bios to see if i can fix it.
Hmmm that sucks. Maybe it's more complicated. Will have to have another look through the bios.
New drivers out... 314.14... http://www.geforce.com/drivers/results/58183 beta
Thanks you guys we all appreciate the work you do for the community
Tested card two today
i knew that it was a better clocker during some easy testing while i modded the cooling on the other one.
Al least this one runs 1200... ok it goes down to 1160 sometimes but its better then the other one is at stock before cooling 1150 was shakey 1160 hard lock.
Great titan vantage scores i'v been seeing at hwbot the last few days ..keep it up :)
http://imageshack.us/a/img824/3995/tvantage55725.jpg
Hmm, I was playing BF3 with my new Geforce Titan card (non overclocked), and after a while I got the following error: DirectXFunction "GetDeviceRemovedReason" failed with DXGI_ERROR_Device_Hung: Device hung due to badly formed commands. GPU Nvidia Geforce Titan Driver: 314.09
I'm hoping this is due to some early drivers that are not yet 100%?
I get this....my first ever DOA.
http://i46.tinypic.com/28gxu7b.jpg
maybe drivers, maybe bios, maybe faulty hardware. let's hope it is because of drivers or bios.
I already tested with two other Titans. They're working fine on the same test bench. Funny that the defective one has the newest serial number and little Torx T6 screws instead of Phillips heads.
Here you go
http://www.filedropper.com/xsbiom
Holy :banana::banana::banana::banana:, at 2560x1600 everything maxed I was getting dips into the 30's FPS with SLI Titans. Crysis 3 is BRUTAL. Good luck playing that with 680's lol
Hello,I just joined to xtremsystems. I follow this forum but was not registered. You are doing good work for people aqui. I see several people of other sites. I am with the same nickname "zupernico" in hwbot.
I have two titan. I'm thinking flash the bios, but I've never done this in nvidia, Ati is very easy. I do not know if I will dare, I will try to learn here. There are many people who know much here, but my English is very bad and I am a bit clumsy for this. thanks for the help you have given me unknowingly and for the help I will receive in the future.
Regards
Just make your usb stick dos bootable.
Put NVFLASH on it and flash with nvflash -5 -6 xxx.rom
That's all...if you're searching for the bios and nvflash, send me your email!
Hi Dancop,thanks
Nacho Arroyo put this nvflash: http://www.techpowerup.com/downloads...ash_5.127.html
And
CrazyNutz put this kgb https://www.dropbox.com/s/dk54rmgce0...gb_titan.zip?m
it?s ok??
my problem is make usb stick dos bootable in this moment :( and flash the bios $(
Guys, what does KGB do for Titan?
Dancop very nice vantage(and the rest too)runs man!
that guy AngelNa had some great runs yesterday too.
BUT since no public vmods its all cpu right now,hopefully we can get some guidance in the next few weeks from the pros.
