yes, it works here too with auto settings. But if you move nb/ht multiplier from auto to anything else it gives FF. Just like in 1.5b1...
http://resources.vr-zone.com/image_d...73dc6a40e4.jpg
LOL 1.53...
2000 HT solved... so far so good :P
AUTO = 10x
NB 2000
HT 2000
http://www.coolaler.com.tw/toppc/MS7550/75772.PNG
ok, i've just flashed 1.5b3 and the bug is still present
Toppc, i know auto gives me 10x, my problem is i'm still unable to use it on 12x.
i might be the only one with this problem but can anyone else boot higher than 215htt on the 1600 mem div????
yeah im using the msi in my main rig got my ram @ 1760 7-6-6-15-12
i had to do this using AOD and win-memtest tuning in windows and when i find that happy oc i then use the multistep oc boot option set to 1 boot low then oc in win automatically in windows works like a charm but a huge pita for tuning memory
im going to try 1.5b3 tonite
Thanks works for me...HT upto 2000, now working on memory and high NB
Where's 1.5B3? :D
Yup thats right, wont boot if i set anything to over the auto. So it is stuck at 2000 mhz, and can only move it with the fsb.
i got my board back from an rma, flashed the bios up so i could unlock and now i have 2 problems. 1) with every bios i tried the fans will not spin down on any header (it came back with 1.30) and 2) affter unlocking nothing reads the temps they are just at 0 and i know that i didnt jump the max since im on liquid and the rad isnt vary warm
it dose seam stable and the the cpu temp seams accurate for an ihs temp
1) I've never had a problem with the cpu fan header and a pwm fan. I don't know about the other headers since I've never used them.
2) With any unlocked x2's and x'3's the core temps go haywire and read 0C. Every board I've seen has this happen when you unlock.
Nope it does not. Evevrest will not give you individual core temps, only the cpu temp. And that you can get even with HW monitor. Anyway this board runs a lot warmer than my old biostar 790GXB, so wondering if the temp sensors are borked or what. I used to idle at 24-25 degs on the cpu, and 36NB. Now its more like 28-30 on cpu and 40 on NB. Are the sensors in differnet places on these boards??
the temp sensor for the MB i think is the NB and the aux is the pwm or its the other way around. i dont really care about the core temps but they were just zeroed and it seamed weird.
also with the gd70 u need active cooling on the NB i put the 40mm from the blackops on the NB (just screw it in the fins will lock it down) and it dropped the motherboard temp by 20c and the aux by 15c
Is that a 40X10 or a 40X25 mm fan??
This is correct?
http://img36.imageshack.us/img36/6417/everesth.jpg
Also my temps are pretty good in a case with decent airflow. I think nb/sb fan is unnecessary.
my MB temp was over 60c
Bios 1.5b3 I can change NB fine. I don't change HT Link because really no performance increase.
http://img19.imageshack.us/img19/4982/captureybz.png
