Why are the voltages all reported as 1.1v?
Wow, another super chip there C-N! lucky you ;)
OCM :up:
2D Benches:
http://hwbot.org/signature.img?iid=5...se&iehack=.jpg
Still have a lot of work ahead of me in Super Pi and timings/subtimings.
OCM :up:
Sure, ill contribute some to this.
http://i131.photobucket.com/albums/p...s281/gflop.png
Somehow CPU-Z reports qpi/vtt with the UD5, they have it working on the UD7 so not sure why we cant have it fixed!
Ye things are going good atm..... should buy a lottery ticket :D
What vcore you running your 2600 at & have you got internal pll enabled or disabled for your 5.2**GHz runs?
Love the flops guys, I've started putting some results in the 3rd post in of this thread & when I get time I'll sure add a Gflops league table....Quote:
Originally Posted by ProStreetCamaro
Lets have a my Gflops are bigger than yours competition!
http://img.photobucket.com/albums/v4...ro/Holycow.jpg
Thnaks mate, I havent thought about it but as you are asking I'll probably hold onto it for now just to make sure the 2600 breaks in ok then build a new work rig with it.
F6c is out.:D
Mr. Stasio, what is new in F6c?
Any clue?
A new bios f6c, yummy. I will test it out tonight after work.
Yes.
OCM :up:
I am liking that build, very clean there OC. I currently have two monster liquid systems and my Torture rack which is the shad. I am planning yet another and this time I will be using the new rev2 Moa3 from watercool in Germany. Very nice build quality and I could replace the rad in my truck with this, massive is the word.
wow OCM that is one sweet setup there :shocked:
2600K is rocking.... going to be fun benching this one :D
Cant (fails test 15) & probably wont bother trying again to get it to run 32M
http://i106.photobucket.com/albums/m...600K/57GHz.png
Nice! Looks like you found one. Careful now and lets see some numbers. Awesome job C-N.:cool:
ads CN to my hate list :shocked:
it's probably just heat mate, make the CPU colder and also try bumping vtt a bit and vmem
other thing you can do to reduce temps a bit maybe is run 2 cores only and no HT
That is a seriously nice 2600K C-N :up:
Thank you ;) Note the splatter all over my screen. Acetone can be a real b:banana::banana::banana::banana: :)
Thanks ;) Got it setup where I can just swap out GPUs thru QDC's or just run the CPU on water. BTW, A/C is sitting 2' away from the radiators blowing full blast. Fans on rads are blowing right on over the board. Everything stays nice and cool to say the least :yepp:
@ C-N. Your x57 is making me sick to my stomach. :rofl:
I need to get my hands on another chip ASAP.
OCM :up:
whau, this is nice! How about max stability (example with safe 1.4V, I dont believe datasheet and 1.52V is right for aircooled 24/7, Francois told nothing and Im waiting at answer :) )
Just pot luck my friend, careful & me don’t play nice together :D
Numbers will come after I have to burnt the chip in & fully understand the voltage ranges it likes. Going to explore 5GHz with 4/8 SP1 first as that’s where I'd like to run 24/7.
LOL
Could be related but they still looked good to me, I have a single stage somewhere that might see the light of day again if I get carried away.
Gave it up to 1.2vtt made no difference but didn’t try a tad more vdimm.... maybe it needs it at 5.7GHz but I know the ram is good at this speed & voltage up to 5.3GHz with my 2500K
Saving that one, probably won’t drop cores but I really don’t need HT so will probably leave it off from now on.
Thanks, makes me wonder if x57 really is the limit the SB can run.
He he... good game aint it!!!!
Have only run LinX, 3D & Pi at 5GHz DDR2133 HT on with SP1 @ 1.39v in bios & it passed so looks good for my 24/7 setting.
I don’t mind what voltage it runs as long as the temps don’t run away. Its running about 75oC full load LinX on air in a 14~16 ambient which im happy with. 5.2GHz needs more voltage I think 1.45 & then she hits 80oC but I haven’t fully tested 5.2 just short 5/10 runs to get the voltages close.
slap it on SS pronto mate :D
Wow bro nice, you using 2x triples? Whats your ambients because at 1.55 your temps are unreal mate! :)
