To whom it may concern.
http://support.amd.com/us/kbarticles...erPreview.aspx
Fixed a long running VSYNC problem for me, with certain directx 9 games and 2X5770's crossfire.
I went ahead and installed these right over the 11.6 with no adverse problems so far. Opted for these over the 11.7 since I figure these should be newer.
let's try
Will try when I get home and post back
Installs over 11.7b no problems. Can't really see any improvements for my 5870 though, not even through MLAA.
Don't see any FPS increase for Crysis 2 DX11 at all.
Seems same as 11.7.
Running 2x 5870 in xfire.
my current game play,the new AvP runs smooth with these maxed at 2560x1600 with the new cap
got 10 more 3d 11 P points,up to 7576
Thx, checking em out. Does the package come with chipset and AHCI drivers as well? Or its just for video?
Drivers seem ok, having the CCC crash which is a little annoying.
Hrm its crashing no matter what driver package i use.
Plus it enables overdrive by default, which is finicky with other oc proggys like after burner.
Stick with the 11.7s your not missing out on anything, I reverted to them. This is assuming you dont NEED this 11.8 driver like the OP.
In other cases, if your not having issues with 11.7s then wait for official 11.8s.
The word beta to AMD is now preview....:rolleyes:
No problem with 6870 crossfire and 11.8. Seems to be an improvement!
