Originally Posted by
eltinio
Ok, I've done the shaking and tilting and no air came out. I pulled the pump out of the system an will try a simple pump reservoir loop tomorrow.
If it has the same problem with just en reservoir and the pump I'll try to return it.
I was thinking about one other thing, there 2 DD fittings supplied with the pump (those with the short threads), the treads one the one for the inlet where too short so i switched it with an normal fitting. Could this be an problem? This fittng was the only one that worked, I have tried an EK highflow fitting and the thread of that fitting was to short as well.
