Second link:
http://www.mediafire.com/?szoat4oxscl6ib9
Second link:
LinX (0.64) 10.3.6.010
http://www.mediafire.com/?cict9u8jki7wps2
Last 2 versions with updated Linpack libraries do not stress at all my Phenom 980, nor does the stop button respond (OS--> XP SP3 x86)
I tried with link from first post and it runs ok....Does anyone have the same trouble ?
I've got the same problem. R3E and R3B with i7 990X. It doesn't load up my CPU anymore? Any ideas guys? IBT works just fine though.
I used the OP version....something seems to be wrong (at least for me) with last versions...
Thank You
Linx 0.6.4- new library (10.3.7.012)-English
http://www.mediafire.com/?3aa7yz5nxfkb97z
http://www.mediafire.com/?isq641lmy7a82i5
The changelog and readme files were in ANSI format, the encoding was unreadable so converted to Cyrillic (Windows) then translated from Russian to English and resaved them in Unicode format so they are now readable. :)
Does not work:
Invalid or Deleted File.
The key you provided for file download was invalid. This is usually caused because the file is no longer stored on Mediafire. This occurs when the file is removed by the originating user or Mediafire.
If you believe you have reached this page in error, please contact support.
Click here to view our help resources
Any workout for the non-loading scenarios ?
I believe the non-loading scenario only experienced by AMD users, Intel users should be fine. This was what I got from Intel website regarding LINPACK,
I solved the problem by downloading IntelBurnTest v2.52 by AgentGOD and copy/rename the LINPACK files inside LinData folder into LinX folder.Quote:
Intel's compilers may or may not optimize to the same degree for non-Intel microprocessors for optimizations that are not unique to Intel microprocessors. These optimizations include SSE2, SSE3, and SSSE3 instruction sets and other optimizations. Intel does not guarantee the availability, functionality, or effectiveness of any optimization on microprocessors not manufactured by Intel. Microprocessor-dependent optimizations in this product are intended for use with Intel microprocessors. Certain optimizations not specific to Intel microarchitecture are reserved for Intel microprocessors. Please refer to the applicable product User and Reference Guides for more information regarding the specific instruction sets covered by this notice.
Notice revision #20110804
1) Rename the LINPACK files inside LinX folder (linpack_xeon32.exe and linpack_xeon64.exe) to linpack_xeon32_OLD.exe and linpack_xeon64_OLD.exe.
2) Copy files inside LinData folder (linpack32.exe and linpack64.exe) into LinX folder.
3) Rename the newly copied files to linpack_xeon32.exe and linpack_xeon64.exe respectively.
You might not get the latest LINPACK version (v 10.3.7.012) but the AMD-patched LINPACK files were compiled on July 20, 2011, not that far off. :D I use Phenom II X2 555 BE and it works perfectly after the modification. I'm not sure if this workaround works for those with Intel Cpus but I think it should work as well. Kudos to AgentGOD for the AMD-patched LINPACK files. BTW, I use both IBT and LinX but I prefer LinX due to the progress bar and the elapsed time display.
To make things easier you can download the patched files here at datafilehost.
Code:http://www.datafilehost.com/download-5930ce6b.html
Yep...that works perfectly..
Thank you
Nice, thank you
There we go, this is with the changelog and readme in English: http://www.mediafire.com/?66bsnawogu0wxdoQuote:
Originally Posted by Opteron146
Linx 0.6.4- new library (10.3.9.015)
http://www.mediafire.com/?5f8ndlr7lvicdq7
Thx Stasio, good find !
