Fermi's do great with AA. Without AA the 5970 is 1.7 times faster than the 480, with 4xAA and AF the number drops to 1.4.
Yeah, even 1.4x is higher than the usual percentage by which 5970 is faster than 480.
This is more a less a TWIWMTBP game but in AMD favour, just look at the hardocp article and it becomes obvious. The graphs and marketing tools should make it more obvious those.
[H] reviews AMD slides ... Good ...
Yes and no. IMO, it's a lot like Far Cry 2 in terms of optimizations.
When AvP was first released, ATI cards walked all over it in DX9 and DX10 (no mention of DX11 simply NVIDIA had nothing to compare). However, both ATI and NV have been at the top of their games when it comes to optimizations for it. Just like FC2 was a TWIMTBP game that proved to be quite even performance-wise for both companies.
Also -and unlike FC2- the developers themselves have rolled out SIGNIFICANT performance improvements over their last few patches for both vendors' products.
As such, I think AvP is one of the more vendor-agnostic games out there right now regardless of ATI's support. :up:
I ran the bench another 3 times after seeing Felix's 5870 results as my first result was much lower. Low and behold, the next 3 runs were magically higher :rolleyes:
*DX11 Hardware Detected*
Using Default Video Settings:
Resolution: 1680 x 1050
Texture Quality: 2
Shadow Quality: 3
Anisotropic Filtering: 16
SSAO: ON
Vertical Sync: OFF
DX11 Tessellation: ON
DX11 Advanced Shadows: ON
DX11 MSAA Samples: 1
Benchmark Summary:
Number of frames: 6901
Average Frame Time: 15.2ms
Average FPS: 65.8
Did a few more runs with textures set to high and 4x AA ;
Using Video Settings from file <avp.txt>:
Texture Quality: 3
Shadow Quality: 3
SSAO: ON
Vertical Sync: OFF
DX11 MSAA Samples: 4
Benchmark Summary:
Number of frames: 4095
Average Frame Time: 25.6ms
Average FPS: 39.0
@ ElSel
Although you are running 1600x1200, 1680x1050 is still 88% the pixel count so the difference will be marginal. You shouldn't have put so much weight in my initial result, especially in light of Felix's result. Don't be so quick to jump to conclusions my friend :up:
hmm does not seem to be CPU limited... Scaling sux max of 67%...
http://i18.photobucket.com/albums/b1...titled8777.png
This benchmark is definitely pro AMD, because it seems to use crossfire but not SLI. I just ran the test at default settings, and I checked my GPU usage and there was only activity on one GPU (second GPU didn't use no more than 10%):
Resolution: 2560 x 1600
Texture Quality: 2
Shadow Quality: 3
SSAO: ON
Vertical Sync: OFF
Benchmark Summary:
Number of frames: 2760
Average Frame Time: 38.0ms
Average FPS: 26.3
Keep in mind my benchmark was at 2560x1600 without SLI.
man mine suck big time
AvP D3D11 Benchmark Report
* Report Created: 2010-05-26 @ 20:43:40
* Executable Build: V1.03, Apr 19 2010
Texture Quality: 2
Shadow Quality: 3
SSAO: ON
Vertical Sync: OFF
Benchmark Summary:
Number of frames: 3380
Average Frame Time: 31.0ms
Average FPS: 32.2
Thats me
* Report Created: 2010-05-26 @ 22:32:34
Resolution: 1920 x 1200
Texture Quality: 2
Shadow Quality: 3
SSAO: ON
Vertical Sync: OFF
Benchmark Summary:
Number of frames: 4817
Average Frame Time: 21.8ms
Average FPS: 45.9
Use command-line option '-logframetime' to report performance frame-by-frame.
GUI time :D
http://www.framebuffer.com.br/sites/.../sshot-146.jpg
Alien vs Predator Benchmark Tool
Edit: Links updated at 7/14
x86 Systems
x64 Systems
Nobody with DX9/DX10 results? :(
DX11 only and from where I am standing, not a very good representation of the actual in-game performance.
It's a shame too because we're sure to see AvP benchmarks using this tool to start popping up in numerous reviews due to its ease of use. Meanwhile, it doesn't give accurate results in relation to actual gameplay so hopefully sites will realize this and either use the game itself or not include AvP at all in their reviews.
* Report Created: 2010-05-27 @ 19:20:12
Texture Quality: 2
Shadow Quality: 3
SSAO: ON
Vertical Sync: OFF
Benchmark Summary:
Number of frames: 5927
Average Frame Time: 17.7ms
Average FPS: 56.6
980x @4 -- 2x 5870 stock
5870 @ 1050/1275
Resolution: 1920 x 1080
Texture Quality: 2
Shadow Quality: 3
SSAO: ON
Vertical Sync: OFF
Benchmark Summary:
Number of frames: 6721
Average Frame Time: 15.6ms
Average FPS: 64.1
1090T-stock/5870E6-stock
* Report Created: 2010-05-27 @ 00:01:11
Resolution: 5908 x 1080
Texture Quality: 2
Shadow Quality: 3
SSAO: ON
Vertical Sync: OFF
Benchmark Summary:
Number of frames: 2687
Average Frame Time: 39.0ms
Average FPS: 25.6
your gona kick yourself here, im 10 FPS faster with same settings and card :yepp: im more up with the 480 results
this is a GTX470 on default clocks :up:
* Report Created: 2010-05-27 @ 20:04:08
Texture Quality: 2
Shadow Quality: 3
SSAO: ON
Vertical Sync: OFF
Benchmark Summary:
Number of frames: 4807
Average FPS: 45.8
THIS TEST IN GAME
http://i40.tinypic.com/30shfgm.jpg
http://images.hardwarecanucks.com/im...5870SOC-33.jpg
Try in Vain AMD :down:
where do you find the benchmark results?. Edit; I found it.
Cpu: i7 930 @ 4,00 Ghz
MoBO: Asus P6x58D Premium
Ram: 3 x 2GB
Vga: GTX480
OS: Win 7 X64
* Report Created: 2010-05-28 @ 11:19:16
Resolution: 2048 x 1152
Texture Quality: 2
Shadow Quality: 3
SSAO: ON
Vertical Sync: OFF
Benchmark Summary:
Number of frames: 6021
Average Frame Time: 17.4ms
Average FPS: 57.4
