Am i correct in assuming (despite the lack of firewire port) that this kit; PW-IN20AH50T0 will work with the PC-V351B ?
Thanks much
Thanks much
That will fit, yes. However, the PW-IE20AH51T0 would be a better choice as there would not be a hole where the fireport port is. It is, however, out of stock in the US. You would be able to order it from us if you want, through the form below. Both will work, so the choice is up to you. :)
http://www.lian-li.com/en/contact-us/
