Hello,
I currently have a TFC Xchanger 360, I want to change :D
Is that Ek Waterblock XTX 360 is more efficient (equal ventilation) or it is the same?
I looked for reviews with these 2 rad "together" but I have not found
Thanks so much ;)
Hello,
Thanks so much ;)
Difference most probably will be small (<10%) and definitely not worth purchasing of new rad.
P.S.
In LC imho it's best not to replace/upgrade rads (unless original rad is VERY bad, eg. mistakenly chosen/purchased high finned rad like GTS even while intended to be used with slow/quiet fans, or if it's some old aluminium crap), but add extra rads to loop, if needed.
I doubt that will benefit you much, since you are staying on the same rad. size, if you need a change get a 480 radiator like the XSPC 480.
The TFC is a good radiator. There really is no reason to swap it out for another brand.
