aah your right...But what the hell. better to have too much than too little right?
Got it somewhat stable.. But I don't think it'll be stable in 270 DC.. Never... but I'm sure as hell going to try! :D
I can't get anywhere above FSB221 on my Rev. 2.0 mobo, stable that is, and it's not my Mushkin. I tried 2.5-3-3-6... didn't help. So now I see that I should disable APIC. Should I just reboot, disable APIC in BIOS, format my Windows partition, and then I should get more stable FSB?
I just read somewhere in this topic that the 10.5 multiplier provides better memory bandwitch. Here's my results from Sandra:
11x: 3397/3173
10.5x: 3411/3169
10x: 3384/3146
9.5x 3394/3137
hey TicTac, can you answer this for me,
in what situation would I need CPC to be ON or OFF? I do not know which version of the d10 i want
CPC On forQuote:
Originally Posted by Stang_Man
1 x 128MB
1 x 256MB
2 x 256MB
1 x 512MB
CPC Off for
2 x 512MB
3 x 512MB
2 x 512MB + 1 x 256MB
3 x 256MB
You need a CPC ON D10 :toast:
Yes ... you should read the changelog carefully... i already inform that multiplier 10.5 ... got bandwith spikes in it... 1% higher than any other multi :banana:Quote:
Originally Posted by Alaza
you need D26 Manta Rays XT CPC OFF biosQuote:
Vdimm = 2.9V in bios
Vdd = 1.7V in bios
Vagp = 1.6V in bios
PCI latency = 128clck
Ext P2p discard time = 1ms
that should do the job done.... :banana:
APIC disable it this way.... update processor driver in Device manager menu to Advanced ACPI driver
reboot... go to bios menu ......then Disable the apic... :banana:
lol... nice job there :)
what do these settings change/help exactly?
just want to make sure before i go messing with it ;)
This bios kicks ass. I have gone from 231 to 240 stable 2-2-2 timings with only 2.95 volts. Bravo!
I did. I just wanted to share my experience so people had an idea of how muth band width it actually gained.Quote:
Those two are BIOS settings, right? Never touched them before.
I already use D26 Manta Rays XT CPC OFF, but I was actually recommended to try Merlins BIOS because of the low FSB. And what is it about the D10 BIOS? Why are you modding that one, when it's so old?
I'm already at these:
Vdd = 1.7V in bios
Vagp = 1.6V in bios
Just not the V-AGP. Isn't it at 1.55v standard?
How about for 1 x 512MB + 1 x 256MB? :)Quote:
CPC On for
1 x 128MB
1 x 256MB
2 x 256MB
1 x 512MB
CPC Off for
2 x 512MB
3 x 512MB
3 x 256MB
[q]PCI latency = 128clck
Ext P2p discard time = 1ms[/q]
I'm also curious as to what these do.
that will make your PCI deviceQuote:
Originally Posted by di_entropy
such as HDD,SoundStorm, ethernet,firewire
run alot smoother at high fsb
i'm using that setting
233MHz stable.... Mtec50D chip :toast:
http://home.doramail.com/tictac2/prime-233-1-m.gif
But should we only use it, if we have problems with Soundstorm etc. when clocking, or should we change it anyway?Quote:
If you have trouble with soundstorm and pci devices check the southbrige. Mostly it's a cooling problem.Quote:
tictac you should write some sort of manuals/tips for NF2 users :)
since i got different ram now, i needed cpc off..Quote:
check this, not bad for the volts:)
thanks tictac!
i did this mod along with the vmod with the pencil and i got my fsb from 220 to 240 stable :D
And the pencil mod raises the VDD?Quote:
Originally Posted by Status:72
Yes, it does but IMHO i prefer the use of a VR for this so simple mod.
If you mod Vdd make sureQuote:
between 1.75V - 1.85V :banana:
234MHz here :banana4: :toast: :banana:
http://69.93.183.37/802/26/upload/p673920.gif
nice :) what is that program that u are using to test stability?
im still using prime95 but wondering if there is something better :)
Hi,Quote:
Originally Posted by LorD_Kvadd
Nice FSB! can you provide me some info like Vdimm, Vdd, BIOS, OS used? any tricks you wanna share? :D I got mine at 262FSB with 3.4V but I couldn't go any further (BH-5 DC)
Originally Posted by KODE
3.4v!! bios maxes at 2.9 for me :( did you do a hardmod apposed to a softmod to get that voltage?
yep I did the VDimm mod, 2.9 in BIOS outputs 3.4V or higher if I want to, It´s just a hardware mod.Quote:
