Some of the L041Cxxx batch(s) have produced some nice clocking chips (even though there can be both strong and weak in each batch). Yours is the first I've seen ending with ...236 so I look forward to seeing your results.
I replace my 2600K and wanted to try a 2500K this time. No tweaking at all.
1.36v set in bios. Dont care about the timings, i can press it down to 7-7-7-20 1T and that should do something in S-pi :)
Batch: L041C124
http://img87.imageshack.us/img87/5223/5000h.jpg
Uploaded with ImageShack.us
Batch # L041C106
5.0 GHZ stable at 1.47 but not anything lower.
Can bench at 52X but not 53X but I can boot @ 53X
http://img824.imageshack.us/img824/4413/50ghz.jpg
Wow I thought those C chips were mostly sexy. Too much volts for 5ghz.
How much voltage is too much volts for air cooling? Right now I am able to get my 2600k(L042B243) with 1.5V for 5ghz and 1.525 for 5.2ghz.
I wouldn't be do 1.5 for 5ghz when you can do 4.7-9 for less then 1.4v.
Another quick S-pi test and finally broke my 7s in S-pi.
L041C124
http://img16.imageshack.us/img16/5152/superpig.jpg
Tried to boot at x56 but it just reset to x33. Any tips what i can do to try boot over x55 ?
SB seems to have both stronger and weaker in every batch... although some batch(s) seem to be a little more consistent than others.
I tested three from ...C106
~ VID
1@ 1.250v
1@ 1.245v
1@ 1.210v
I've been holding on to the 1.210v sample... seems to boot 54x but not 55x
and I'm not sure where/what the max bclk frequency is for it?
http://www.xtremesystems.org/forums/...postcount=1539
another nice ...C124 sample...
High multi (bootable) chips 56x(+) are pretty rare and randomly chip dependent.
If bumping vcore doesn't help with booting 56x then you may be able to get to 5.6 range via bclk.
Sweet spots for gem 2600K are 54X and 55X, it needs BCLK 107+ and 105+ respectively to compete with 980X @ >6Ghz. Then again rams should be able to run @ high BCLK
56X and 57X are those 2500/2600K that are 5.8+Giger
Got really tired of the problem resuming from S3 sleep with Internal PLL Overvoltage on for 4.9ghz with 1.36v set in bios, 1.4v load under linX.
Currently settling for 4.8ghz with PLL off so the S3 resume from sleep doesn't require a hard power off ond restart:
http://i246.photobucket.com/albums/g...8ghzPLLoff.jpg
Internal PLL Overvoltage: Off
Memory Frequency: DDR3-2133mhz
Load-Line Calibration: Extreme
VRM: Auto
Phase Control: Extreme
Duty Control: T.Probe
CPU Current Capability: 110%
CPU Voltage: 1.32v
Vcore 1.32v set in bios, ranges 1.32v idle to 1.36v max under linX,
Oh yeah, other specs:
i7-2600k L041C108 S/N: 2L043107A4661
Asus P8P67 Bios 1305 on air cooling Venomous-X 2 fans (can probably drop a fan on 4.8ghz...)
Win 7 SP1 x64 with AVX
$79.99 G.Skill F3-12800CL6D-4GBXH (2x2GB) 1.5v @ DDR3 2133 CL7 1.6v!
http://www.xtremesystems.org/forums/...d.php?t=266839
No other changes in VCCIO, VCCA, PCH, or any other major thing in the overclocking section.
Haven't had time but got an i5-2500k L041C123 I'm going to drop in soon to see if i can get higher with PLL Overvoltage off...:up:
Does anyone know a store that has these- 2600k L041C108
more...
5.1Ghz
Prime95 Blend: 10:32h
Frecuency: 51x100
LLC: High
Offset: +0.150
Vcore: 1.48-1.49v
Temp. max: 61-65-67-65 (18º ambient temp.)
http://img820.imageshack.us/img820/2...ghz148v.th.png
And Gflops at 5Ghz:
Core i7 2500k@5.0GHz - 125,00Gflops
http://img46.imageshack.us/img46/602...s5ghz2133c.png
http://img263.imageshack.us/img263/3842/img4718b.th.jpg
I'm going to pickup some 2500k and 2600k at Microcenter , Any one here have experience with batch code number lately at MC ?
Which MC? At the Twin Cities/Saint Louis Park, MN, there are four batches currently available: L040B305, L042B208/243 and L050A853. Neither of these are great OCers, by the way. I have the L050A853 and it seems to be the better among them. But then again, it could just be my crappy board. Who knows since I don't have two boards to compare, I really don't know.:shrug:
Think its just random luck guys, I have a L050A864 & its a champ
Runs 100BCLK 0.01v lower on 2 cores & .025v higher for 4 cores
http://i106.photobucket.com/albums/m...R2215W732M.png
I've tested a few of the L050A853 and some of them are quite decent but as with most SB batch(s) there is both stronger and weaker samples out there.
I would consider that batch if it were available at your MC... also another decent batch that may still be at some MC is the L041C108 batch.
Has anyone tried an L040B705 ?
:shrug:
lol I posted WTB for decent 2600K but no bites, I think they are that hard to get that anyone with one will hold on to it.
Many of us here have gone through many chips before getting one that really cranks beyond multi 55 so yes we tend to want to keep them around.
