Good combo for a water cooling loop drain?
Ahhh, the joys of draining your loop(s)!
I hope to make this process easier by installing a drain into my loops when I set them up. Would this be a simple setup to place at the bottommost part of each loop:
Polypropylene "T" Fitting 1/2"
Enzotech Drain Plug G 1/4 Threaded Cap - 1/2" Barb
I would place a little bit of tubing at the bottom connecting the 'trunk' of the t-line fitting to the drain barb.
How does this look? Any problems with flow restriction or anything else that I am overlooking?
