need advice for dual perhaps triple loop system parts order.
Ok here is what i have:
Arctic spider 775 tec block (2 in 2 out)
einheim600 with alphacool submerged pump station
inifinate supply of effecient car heatercores. would prefer 3 max though.
a spare horrible cream pc case that may come in useful.
a spare meanwell 320-12 (as well as my 600-24 for arctic spider)
Here is what i want to do:
Cool the Arctic spider effeciently in one loop.
Cool the gpu,mosfet,northbridge in another loop (or 2 if recomended but
would prefer one loop if possible.
things i want to get:
- 1/2" id tubing and pump and perhaps bettter nozzles for arctic spider
loop.
- 3/8" id tubing, gpu block, nb block, mosfet block
considering the silverprop tec block as i have a spare meanwell 320?....
maybe ram blocks if i thought i would get higher mhz keeping stock
latencies?
What i am asking you?:
well the size of project and range of parts i need has me a bit overwhelemd so i am looking for advice on what to get for the system.
i have one idea of putting all the t lines pumps and rads into my old case and sealing it totally with 2 x120mm fans on top and 2 on the other side pulling ambient temp air constantly though the case.
my sysstem specs are q6600, abit AB9 Quad gt, 4gb ocz 6400 15-4-4-4, radeo x1900xtx.
any help to give me some direction would be great! thanks.
