Futuremark Readies 3DMark TimeSpy Extreme Benchmark
https://www.techpowerup.com/237513/f...reme-benchmark
Futuremark is giving final touches to its top-tier GPU benchmark, 3DMark "TimeSpy Extreme." This benchmark tests your graphics hardware's performance at the 4K Ultra HD (3840 x 2160 pixels) resolution, with the latest DirectX 12 API. You will need a graphics card with at least 4 GB of video memory to run the test. The benchmark will put not just the fastest graphics cards through their paces, but is also designed to take advantage of today's multi-core processors.
3DMark "TimeSpy" Extreme can take advantage of processors with 8 or more CPU cores, and will benefit from the processors supporting the modern AVX2 instruction-set. Futuremark claims that the CPU tests of "TimeSpy" Extreme will be 3 times more demanding. The company also mentions that it developed the new benchmark while taking inputs from AMD, NVIDIA, and Intel. The benchmark is expected to launch on the 11th of October as an update.
