I'll share some settings from a 3D benching session the other night.
3DM06 Bot Link
System is Sig. P09 Bios:
Code:CPU Features
PPM : Disabled
EIST : Disabled
CxE : Disabled
Execute Disable Bit : Disabled
Virtualization : Disabled
Hyper Threading : Enabled
Active Processor Cores : All
Memory Settings
Memory Controller Settings
IMC Configuration : Enabled
Channel Congifuration : Independant
Channel Interleaving :6-Way
Rank Interleaving : 4-Way
Memory Timings
Extreme Memory Profile XMP : Disabled
Memory Profile Select : Manual
DRAM Timing Control :
tCL (CAS Latency) : 9
tRCG (RAS to CAS Delay) : 9
tRP (RAS Precharge) : 9
tRAS (Precharge Delay) : 24
CR (Command Rate) : 1T
tRFC (Refresh Cycle Time) : 92
tWR (Write Recovery Time) : AUTO
tWTR (Write to Read Delay) : AUTO
tRRD (RAS to RAS Delay) : AUTO
tRTP (Read to Precharge) : AUTO
All Voltage Settings
CPU Voltages
CPU Core Voltage : +250mv = 1.376v
CPU Target Core Voltage :
CPU Vdroop Compensation : Disabled
CPU VTT (UnCore) Voltage : +260mv = 1.450v
1.8 PPL Voltage Setting : 1.9v
CPU Clock Amplitude Ctrl : Default
Memory Voltages
DRAM Voltage : 1.80v
DIMM1 Vref CA (Addresses) : Default
DIMM1 Vref DQ (Data) : Default
DIMM2 Vref CA (Addresses) : Default
DIMM2 Vref DQ (Data) : Default
DIMM3 Vref CA (Addresses) : Default
DIMM3 Vref DQ (Data) : Default
Chipset Voltages
X58 IOH Core Voltage : 1.300v
X58 IOH VCCA 1.1V : 1.14
X58 IOH VCCA 1.5V : 1.553
ICH10 SB Voltage : 1.553
OC Gear :
CPU Turbo : Disabled
System Turbo : Enabled
Clock Speed Control Center
CPU Bclock (FSB) : 200MHz
QPI Link Fast Mode : Enabled
QPI Multiplier : 18x
QPI Target Speed : 3605
CPU Core Multiplier : 23x
CPU Core Target Speed : 4603
CPU Uncore Multiplier : 16x
CPU Uncore Target Speed : 4010
Memory Bus Multiplier : 8x
Memory Bus Target Speed : 2005
PCIx: 102MHz
