Should be a good one as far as winchesters go. :) GL :toast:Quote:
Bringing back the good ol winnies? Too bad I lost most of my pics :confused: but back when I was using mine it would do right under 2.6 24 hr prime stable. Heres the only pic I have left on the 9 multi. (remebering at the time I was seeing how far my gskill could prime for 24 hrs :) )
24 hr prime stable 2.5ish on air. 288x9 was max prime 24 hrs with a little more volts on my trusty neo2 wich Im still using with my X2 4400@2.7 :toast:
Hello XtremeSystems Forum, my first Post this is ;)
This is my max Mhz on my Winchester not stable on SuperPI.
I tried to get it over 300HTT but that was no go.
*Water with Window up*
Cuplex Pro, Dual 120mm Rad, Eheim 1048.
300*9=2700Mhz 1.6V+ (CBBFD 0437VPMW)
166 3-3-3-8 2.85V
http://www.kirkedam.mine.nu/kwk/Data...eh20300fsb.JPG
RAM is set on crap mode just to get high HTT.
http://www.kirkedam.mine.nu/kwk/Data...g/PICT1179.JPG
Aprox Temps
Around the computer=12c
CPUtemp=10-15c
Ramtemp=10-14c
Outsidetemp=1,6C
Watertemp=12c
Not all temps are Accurat.
some Winchesters just wont do 2700mhz. you could try lowering voltage, as some Winchesters dont like voltage 1.6 and up.
I can get the winnie that I just bought from Mad Mikee up to 2.8ghz at 1.62v. I'm not sure of the stepping, because Mikee said he sent me an IHS from a different CPU. I haven't taken the time to try SPi 32m, but it's completely D2ol stable. Been running D2ol at this speed for 5 days straight.
This stepping is good? what the maximum that I can arrive with it?
CBBHD 0450wpaw
winchester 3000+
now i'm stable at 2520 315X8 1.5V
and this is the best(stable) that i can do with my motherboard for now
(GB K8NF-9, soon DFI lanparty ultra-d)
Have a look below.
http://cgi.ebay.co.uk/Athlon-64-3200...QQcmdZViewItem
er, are all the winnies still alive? :D
ok, anyone with winnie able to run 2x1gb sticks beyond ddr520?
i tried my 3000+ winnie on both neo2 plat n ep-9nda3+, my rams cant go beyond ddr520..
this same ram on newer system i see [venice,opty, nf4 boards] able to do ddr560 easily..
so i wanna know whats my limiting factor here..
izzit my winnie, or the nforce3 boards :(
ok, juz checked my bios...
probably winnie's mem controller cant handle 2gb at high htt
@htt255
http://img142.imageshack.us/img142/749/htt2555nu.th.jpg
@htt256
http://img142.imageshack.us/img142/5...t2560wz.th.jpg
heard same probs with another winnie user with pqi 2gb kits stuck at ddr480
will try a venice to confirm this ;)
Yeeeej, got watercooling today, raised my prime stable overclock on my 3200+ winny from 2450mhz@1.5v to 2700mhz@1.63v ! :D
DFI Lanparty Ultra-D
3200+ @ 10x267.9 = 2.68GHz
CBBID 0502APMW
1.5V x 1.1% = 1.65V in BIOS
air cooling: XP-90
UTT @ 243.6 2-2-2-6 1T
Vdimm @ 3.5V
me :: thread
:stick:
I have a 3200 winchester and was wondering something...
I can run it either way, but one is prime stable and the other is not im wondering why cause to me it looks to be the same.
240x10 =2400mhz, ram at 240..this does not prime more then about 10mins.
253x9.5 =2403, ram at 240.. this does prime *Ram is set to 1:1, but uses divider cause of .5 multi*
Now, am i crazy...why does my ram do 240 when its on a divider and not when its 1:1?
Explain to me why one works and the other doesnt. I mean the to me, the ram in both are running 240, and the cpu is 2400.
3500+ winchester
MSI K8N neo2 platinum
OCZ bh5 pc3200 sticks
Thermalright XP-90 w/92mm tornado (yes, its noisy. i don't run it at full blast)
OCZ 520W psu
thermaltake armor (black) case
running memory at 3.4v 2.5 2 2 8 @ 250 x 9.5 = 2375
cpu is at 1.49v
going to try for more here soon, this is just what i started playing with.
that is my same setup :cool:Quote:
Originally Posted by ZL1Killa
gj
This was the most I could pull from my 3500+ Winny under water :)
Loose memory at the time.......28second 1M Pi was my fastest with this cpu.
My poor Winnie 0502GPFW wouldnt go above 2.4Ghz no matter what I did :(
even on Ultra -d with any voltage (tried up to 1.62, didnt wanna go further)
