very nice , may have to try this out
The tool can ! but i am not sure about results ... P35 boards and P45 boards are not the same !
P45 is not a simple overclocked version of P35 (X38 -> x48) !
If it was me, i don't do that, but if you will, do this at your own risk (but maybe too much risks !).
ThanksQuote:
Originally Posted by Mr.Guvernment
i tried to flash again the other day from 0703 i got from you through those updates to latest bios on P5E3 DLX but when i select the option it sort of doesn't do anything.........it spits out a few commands and then just stays at one part of the screen not giving me options to continue further to flash :confused:
maybe i should redo the whole stick all over again
Very nice stuff KODA:clap:
Hi,
Can I add new bioses for my P5E WS Pro to the key? Just got hold of the 0704 and 0801 bioses (the latter is one of the best for this mobo). Somehow the .ROM files should be converted to .imz files (located at \images\X38). And the p5ewspro.cfg (at \menus\X38) should also be updated with information of the new bioses. Perhaps something like:
-snip-
MENU CMDLINEROW 12
MENU ENDROW 24
MENU TIMEOUTROW 20
LABEL 0801
MENU LABEL P5E WS PRO Bios 0801
KERNEL /kernels/memdisk
APPEND initrd=/images/X38/5ews0801.imz
LABEL 0704
MENU LABEL P5E WS PRO Bios 0704
APPEND initrd=/images/X38/5ews0603.imz
LABEL 0603
MENU LABEL P5E WS PRO Bios 0603
-snip-
Is that correct? What to do with the .imz files?
By the way. It is a great tool - good work!
Well, you have to modify the p5ewspro.cfg to have theses choices on the screen.
The imz are some compressed floppy images ... so you have to open it with an ISO editor and change the rom file in it ... and edit the autoxec.bat.
However ... i will release an update in a few days (and your bios are on it ... if i could well remember) ... just need some time to work on nvidia's chipset boards.
Regards
Done!
What ISO editor do You suggest (windows based)? I have tried both UltraISO and WinISO with no luck.Quote:
And what autoexec are You referring to? One on the key?
I really need to get my mobo updated with the 0801, and I have discarded my floppy. Furthermore, this key and its functionality is interesting...!Quote:
This is summer day ... but not in the french sky :D
So the new release (0.5) is out ;)
- More than 110 new bios
Changelog :
You can download the USB Key version or the CD one !Quote:
v0.5
- Add Nvidia Series :
Add Striker Extreme 0302, 0505, 0701, 0901, 1004, 1102, 1301, 1303, 1305, 1401, 1502, 1503, 1504.
Add Striker II Extreme 0402, 0508, 0512, 0602, 0701, 0702, 0703, 0704, 0801.
Add Striker II Formula 0101, 0501, 0601, 0704, 0901, 0902, 1001, 1101, 1202, 1303, 1305.
Add Striker II NSE 0305, 0403, 0502.
Add P5K Pro 1002
Add P5Q Deluxe 0204, 0604, 0610, 0702, 0704.
Add P5Q Pro 0205, 0505, 0703.
Add P5Q WS Pro 0110, 0124, 0201.
Add Maximus II Formula 0601, 0603.
Add P5Q 0103, 0107, 0108, 0506, 0703.
Add P5Q-E 0205, 0506, 0604, 0610, 0702.
Add P5Q3 Deluxe 0302, 0507, 0611, 0702, 0704.
Add P5B-E 0306, 0601, 0706, 1002, 1101, 1202, 1501, 1601, 1702, 1704, 1802.
Add P5B-E+ 0108, 0207, 0304, 0410, 0504, 0613, 0616, 0617, 0624, 0627, 0628, 0633.
Add P5B + 0213, 0301, 0401, 0604, 0804, 0903, 1001, 1002, 1102.
Add P5B Premium 0303, 0402, 0604, 0705, 0803, 0901, 0902, 1001.
Add P5B Deluxe/Deluxe Wifi-AP 1233.
Add P5E WS 0704, 0801.
Add P5E64 WS Evolution 0115, 0501.
Add P5E3 Premium Wifi-AP@N 0503.
Add Bios Tools (dmi386, cbrom, AMI Tools ...) in Tools Section.
Fix wallpaper P5E64 WS Evo & P5E Deluxe (bad color code)
MD5 sum are :
08a71d0c95808472c28072997f43025e *KodaKeyCD_v0.5_EN.7z
b11eafd6bcee75072e69e2f4ab2dff30 *KodaKey_v0.5_EN.7z
Now the key contain around 350 bios and use around 360Mb on the key.
Regards.
greet work man
thanks alot
thanks for realease , but i'm wonder that what we can crossflash ? , i'm using p5k-se , crossflashed to p5kr , it's working , but i dont know which one i can crossflash to (before i buy another bios chip for backup , it's so hard for obtain another 8mb eeprom here ( vietnam)
thanks.
sorry but i don't understand what you mean by "which one" ?
which bios version or which other MB bios ?
In case of which bios ... i don't know, you must try them to find the best one for you (but last one could be a good way to begin).
For P5K-SE, the key contain :
Bios 1008, 0901, 0704, 0604, 0401, 0309 , 0205, 0204.
For P5K-R,
Bios 0605, 0403, 0303, 0201.
In case of which mobo ... well, i didn't own the P5K-SE so i didn't try a crossflash ... sorry but i can't answer to this.
regards.
i mean which mobo , i think adding a table for crossflashing mobo is good idea :)
like p5k->p5kr , xxx to xxx etc...
Why not ?
It is a good idea but as far as i'm concerned ... maintain the key is already a job :D
@koda
is posible crossflash to anyone on P5K-Deluxe?
Well, maybe to P5K Premium but i didn't try it (coz i got a premium one :D) !
If you want to try it, don't forget one thing, do it at your own risks ...
Everything here is extrem (we are on XS !).
sub'ed
;p
Great flashing tool. Thanks
Does anyone know if the P5E3 standard vanilla non-deluxe DDR3 board could be flashed to the Maximums Extreme?
Just the BIOS.rom files are a completely different size! (1MB for the P5E3 standard and 2MB for the Maximus Extreme).
John
The P5E3 doesn't support C1 stepping of Yorkfield? I though it did.
It supports the QX9770 and I think the Q9450 however many people are saying it does not support the Q9300.
BIOS 1002 thread on ASUS Forum
Q9300 P5E3 problems thread on ASUS forum
It's a right joke how ASUS have neglected the P5E3 but regularly update the other X38 bases boards
John
