Hey guys does the Vertex 3 have a toolbox?
Think it is the same toolbox as the Vertex 2 since it is based on Sandforce too.
Try this one here :
http://www.ocztechnology.com/files/s...lbox_v2.36.zip !
It works. Right click and run in XP compatability mode if you have to...
Works great.
Wasn't sure if anyone had posted a benchmark for 2x 240GB Vertex 3's in RAID 0 so I just ran AS SSD real quick.
Already have a few games/programs/data, etc installed so the performance has probably dropped a little. This is all using the onboard RAID from a Gigabyte UD4-B3. Run under Windows 7 x64 Ultimate.
Lemme know if I can run any other tests if people want to know anything about 2x240 in RAID 0. Absolutely loving this combo though. Good bang for the buck.
http://img708.imageshack.us/img708/3528/ssdk.jpg
Here's mine from 1 page back...
http://img148.imageshack.us/img148/5...mapimageya.jpg
Something's wrong with kgk's 4K writes ...286 vs. 46 ????
Write cache enabled?
The difference in performance is no OS VS OS on the array?
Some preliminary test with OCZ Vertex 3 120Gb Maxiops on ocz forum (on P67 sata 6Gb/s):
http://www.ocztechnologyforum.com/fo...l=1#post630268
http://bbs.pceva.com.cn/attachments/...a29c52ffc2.jpg http://bbs.pceva.com.cn/attachments/...6fcd32f53a.jpg
http://bbs.pceva.com.cn/attachments/...9bb5a4d2a4.jpg http://bbs.pceva.com.cn/attachments/...aff58b4bf5.jpg
38MB @ 4K QD1 Read? Nice! :eek:
AS SSD is more or less correct at QD1.
That 4K QD1 write result is rather high, the 240GB V3 is nowhere near that figure.
aha. Toshiba 32nm toggle mode NAND on show, I believe. :)
so are the max iops not equating to the low QD? say it aint so sam!
we need some more detailed testing...gah! wish i could afford a couple (or 8 :) ) of them!
Some testing on the regular Vertex3. Asus Maximus IV Extreme using Win7 64Bit installed as UEFI with the controller set to AHCI along and the Intel "F6" 10.1.0.1008 driver.
Click for larger image
http://www.edgeofstability.com/image...sd_839_a_s.jpg
So, a new firmware in the making :)
Are you disabling write flushing to go beyond 100MB/s on 4K writes at QD1?
Using standard settings my 240GB stays at around 75MB/s
Just a standard UEFI Win7 install. No setting have been changed.
Alright PRAZ - What's the skinny on the firmware????
yea that 4k qd1 write is very good! always have to remind myself im looking at a single device when i look at the V3 benchies :) UBER
so close to ordering 5 maxiops....
