I own a p180b and, for the price, I don't think there's a more complete all-around solution for enthusiasts with a budget.
Style, silence, airflow, bay management, fan control, cable management, the list goes on and on.
If I had the dough to drop on something in the premium category, I think some of the Silverstone and Lian Li cases at the high-end will beat the p180b handily.
But for $100 or less, I think it's untouchable.
For those with the P180, are you able to install a long psu? I'm debating between the 900 and P180 and I'm worried my Silverstone OP1000 won't fit in the P180 because of the fan placement.
Watch out Antec ,the CoolerMaster CM690 have the elegant look of the Antec P182 , the twins top 120/140mm Fans of the Antec P190 ,the full front Mesh of the Antec900 , Plus a Bottom 120/140mm Fan ,Plus a 80mm Fan at the back of the motherboard ,Plus two 120/140mm Fans on the LeftSide panel ,plus cable management at the back of the motherboard ,total of seven 120/140mm fans , all this for about 60 usa dollars (Cheap)
just take out the fan that is by the psu. i modded my p180 for a 120mm fan in fron of the lower hdd bay.
