Have you tried the mod, Tim? :)
http://www.octeamdenmark.com/forums/...6143#post26143
Here is the mod made by me with Paakkis pics
Riska, I not sure but this is not the mods , you need to solder the resistance to a anothers place not just remove it ?
No news for the memory voltmod ?
Look at the pics i am pointing to the solderpads you have to move them to!
And read the text on the pics
Not if the iron isent to hot aka 65watt go for 15-30watt iron
Has anybody already switched the sideport on the card?
What do you mean "the sideport" ?
I think he means the direct connection between the GPUs(without the PCIe-bridge), as referred to by AMD/ATi as Sideport.
This feature is currently disabled AFAIK, but maybe someone know how to enable it?
What will you gain to enable it?
Bandwith, and hopefully some performance. The data that are normally transferred through the PCIe-switch(the one between the GPUs), can be transferred directly between the GPUs, without going through the switch(that means higher datatransfer-speed). ;)
Some said ATi won't enable it, but we'll just have to wait and see. :)
Others said, that Ati is going to reserve this feature until the next Geforce generation.
It will bring the card up to 40% more performance...
All you guys have got a switch on the card, near the crossfirebridge. Did you switch it already?
The switch is for pal/ntsc for the video mode
Sure?
yes i am sure the same was on the 3870x2
any body still looking bios HD 4870X2 TOP ? Default Core 790 / 915
http://img227.imageshack.us/img227/3...70x2topbg1.jpg
GPU 1 : http://rapidshare.com/files/149329073/R700.bin
GPU 2 : http://rapidshare.com/files/149329945/R700.bin
Will these work on sapphire cards?
i would also like to know if this asus bios works on the sapphire 4870x2 cards
are sapphire the only branded 4780x2 cards that have hynix gddr5 ? or are they all refrence to that asus bios.
It works on Sapphire Cards
I think ASUS TOP still reverence I dint see anything different ASUS HD 4870X2 TOP with ASUS HD 4870X2....
I can flash both my cards and they will both work with these bios? I remember doing 2 2900s and after I flashed them windows would only see one card, I found some different bios and flashed one card so they both would not be exactly the same and then windows showed 2 cards...
i just put the TOP BIOS with success....it was the first time. i also added the 1.35v.
i can get the GPU at 845mhz with no pro; i will keep like this but it looks i can push a little more maybe.
im playing oblivion at 1920x1080 and AA 4Xedge-detect and the frame-rates are the same with 800 and 845mhz core...... maybe cpu bottleneck?? but i have a E8600 at 4,285ghz..... dont know.
the problem is the memories.... before i could get 965mhz maximum and then artifacts. now 1000mhz its ok, but i cant push it more because of CCC.
is there any way to overclock the memories apart from trying and flashing it in diferent BIOS?? once i know the right value i can flash it.
thank you!
Take the Rivatuner 2.11
