Same controller config like trans am, should i notice any difference between 64GB and 128GB M4's ? I now am on 4x Vertex 30's Turbos
Loving my new M4... need to build the new pc, it's crippled in sata2 mode :)
Daily spam :p
2xVertex3 MI R0 64k stripe @ PCH sata6G, with win7
Just for comparing.
Attachment 119905
Would it be possible to add an option that just copies the data as plain text? Much in the way that you can in Crystal Diskmark, HD Tune Pro or AS SSD.
Cheers
There is a very simplistic copy text feature but it copies only the points. (beta7)
I'll have a look at copying the other info as well.
Beta7 link is corrupted, won't unzip. Please check and fix.
Thanks!
I'll check the file, it used to work :), however it is obsolete as there is a new beta with some minor changes to the Endurance test.
Beta 8
- 250ms delay for every 1000 files deleted.
- 10 second pause between loops. (used to be 5 seconds)
- files per loop is changed from 9999 to 99999
Link to download
Still can't unpack. 7zip still says unsupported compression method for AnvilPro.exe
Edit: All sorted out now, Anvil is great. :up:
Strange, it works for me using both 7Zip and W7's extract (shell) method. (tried seconds ago)
Will get it sorted out asap. (I'll send you a link to a preliminary site)
It seems the beta 5 has expired. Where can I download a newer beta?
EDIT: Missed the second download link in first post.
EDIT 2: Beta 7 is expired too it seems.
You need beta 8 now, the link for it is somewhere in the endurance thread:
http://www.xtremesystems.org/forums/...Vs-34nm/page54
between pages 54 and 80...
sorry. I can't seem to find it again.
Nice. I was going crazy looking for it and couldn't seem to find it.
A small teaser for the next beta.
Next beta will list the OROM version for the Intel RAID Controller.
Attachment 121366
Sorry I didn't see this. Here you go:
Attachment 121380
Mr. Anvil - any progress on non-testfile read tests?
@One_Hertz
It's close to the top of my list, I'm currently working on full-span endurance.
New beta
Expires 27th of January 2012
-Lists OROM version of Intel RAID controller
Link to download
IntelŪ Rapid Storage Technology 10.6.2.1001
http://www.station-drivers.com/page/intel%20raid.htm
Thanks for the Link :)
Downloading right now...
Does anyone have any list of bugs/fixes for that ?
Thanx
Nvrmind, found it
Hi Anvil
Is it possible to fix it?
Attachment 121499
Attachment 121498
I've seen the issue, most likely you've got unpartitioned volumes/drives.
I'll try to reproduce the issue!
Hey Anvil,
Why am I the only one who ever has trouble ectracting your .zip files?
Always say Anvil.pro is corrupt.
Can you please check it out and/or PM me with Beta9...Thanks!
Not sure why you're having issues, I'll arrange something tonight.
(I checked just seconds ago and both 7zip and Explorer worked just fine)
