Maximum oc percentage compertition
Ok Guys are you ready, if so get you engines started we have a great competition for all UK overclockers, the competition is all about overclocking to the maximum MHZ you can from the stock MHZ using only an air-cooled set-up, this can be of your choice, so no limitations to whatever setup or system you want to run. the best bit it’s in the comfort of your own lair, we invite you to generate the MAXIMUM OC PERCENTAGE possible.
Run CPU-Z on your rig at STOCK speed, then again once you have the OC set to MAX take a CPUz and email those links to asuscompetition@kitguru.net with your name, address and mobile number. The 12 fastest overclockers will be invited along to the finals.
Good luck lads I know you will do us proud.
All info can be found hear:http://www.kitguru.net/site-news/com...-great-prizes/
