Originally Posted by
Computurd
I have a vertex that i received from a RMA situation. It 'panic locked' and could only be broken free of this by means of using a firmware flasher that isn't generally released unless you have a specific problem.
However, these panic-release flashers are released regularly to people with problems, they talk about them all the time in the vertex area of their forums. Only given via pm or email whatever with support.
So they sent me a few of these flashers, as they match up to certain configurations with the type of nand on the vertex series, as there has been a few versions over the years.
When none of the versions worked on my drive, they happened to ask me directly if the drive was received from an RMA> when i told them that it had in fact been an return from a RMA drive, they informed me that drive there wasnt a flasher for, and it had to be sent back.
Struck me as odd then, and still now. I believe it was a refurb and something akin to what you are mentioning is the situation. Otherwise, why would only a drive that was received from an RMA return the only drive that they did not have a flasher for(or at least one they are willing to release)?
