Gave up trying the this way.
Ended up using GUIMiner-scrypt
In AMD OverDrive I set core to 885, memory to 1300, fan on auto, power control to +20.
In GUIMiner-scrypt I chose the 7770 preset and then changed the Intensity to 14 as I work on this PC as well.
7770 now running at ~185 khash/s
After some tweaking on my 7770...
OC'd using TRIXX: 950 gpu, 1375 men, 1125 vddc, +20%
Fan on auto (max 54%), temp 68C max
http://imageshack.us/a/img507/7565/rqim.png
Why'd you blank out certain details? I'll happily tell the world that my username is "flyingsuicide.1" and the password is "x" - no lies, try it out ;)
All that will happen is any work you do will be credited to ME :D
Fixed just for you Jonathan :up:
So yes, everyone use my settings please :D
Just picked up two Sapphire 6970's...should get them Wednesday and have them up soon after on free power :D
Here's to hoping for ~525 kh/s min each card :up:
I finally got both of these Sapphire 6970's going over the past 2 days. Both cards running 940/1450 @ 1.150v and 75% fans (2750rpm). They can peak at 88C for brief periods, but one stays at 79-80C usually and the other that I replaced the TIM on at 75-76C.
Pulling 512kh/s avg per card mining either LTC or DGC with:
-w 256 -v 1 -I 20 -g 1 -s 5 --thread-concurrency 8192 --no-submit-stale
