you have full size image? I can't see some memset settings :p I recieved my E6850 this morning and demounted my pot - board is a little wet and it has to dry a bit before I can start everything again.
I'll keep you posted in the afternoon...
I'm not home right now, but I will upload it later.
seems that the widely told fact that P35 and 45nm chips won't give you that much FSB is true...with my 65nm E6850 I can easily hit 565 FSB (but not 575...) with 1.625V nb
http://s8.directupload.net/images/08...p/wjload8t.jpg
I currently run 32m but football just started so I have to stop testing for now ;)
550 FSB with 1.52V nb http://s8.directupload.net/file/d/1467/lr5pvz5d_jpg.htm but everything 5-5-5...CL4 only works till ~530.
€dit:
The 565 FSB rig ;) 32m passed but the screen over at the bench rig...nonetheless mars can do (semi-) high fsb with the right chip ;)
http://s8.directupload.net/images/08...p/w6xfymkt.jpg
so you got 565fsb suicidable even with a 45nm chip?
did you see the russia netherlands match?
geez, when did russia get that strong? or did the netherlands suddenly suck so bad?
no this is all with my E6850 65nm as you can see. but that worked quite well so you just have to have the right chip maybe. 45nm doesn't seem to give that high fsb on the mars considering the pretested chip from mpc.
that only leaves one question for his 600 fsb chip - which board it was tested on before?
probably 965? ^^
@SoF:
http://i228.photobucket.com/albums/e...l/ba04e424.jpg
Better?
Did you find out anything new with the 45nm? If there will be no sollution for the problem I will change back to ASUS -.-
@saaya:
Anything new from Shamino? Does he have any kind of idea? Maybe BIOS problem?
Yeah that was a great game.
The Final is going to be Germany against Russia :D
I sold the Board now...I was pretty disappointed of it -.-
And It's going to be Germany vs. Spain :D
well I ended up with something around 575 FSB with my E6850 but for the E8400 higher fsb was a no-go. Selling this board as well to jump on the P45 train ;)
:,( :D
good luck with your p45 boards guys :toast:
