Cooling 3 R9 390's....
Looking for some input/help with my cards. Currently have them on a Black Ice Stealth GT 360, dedicated loop, with a 355 pump, and push pull Geild fans. Using EK universal blocks, with a parallel bridge. During a gaming session (BF4) card temps will get to 80c. I'm thinking I need to do something with the fans (like get some that push over the current 52.4 cfm) Problem is, I have space issues in the top of the case, so slimline is gonna be a must.
Current Fans: http://gelidsolutions.com/products/i...=1&cid=2&id=84
Current Rad: http://www.frozencpu.com/products/23...c7C&mv_pc=1141
Was looking to go with these fans possibly : http://www.newegg.com/Product/Produc...12&ignorebbr=1
Or, do you think a diff rad, would be necessary?
Any input would be greatly appreciated.
Try serial gpu rig. The flow in any gpu bloks will be higher then in parallel .
yyea i think you would lower your first card temps then the second might be same as now, can you shoot a pic or two..
sounds like a nice rig
SV
hooly thread revival batman!
I'm sure screwtech has figured this out since posting two years ago but I'd have recommended getting Noctua fans on the rad for more static pressure-maybe the higher RPM industrial models. Or ditch the front fans and run some 38mm thick server fans in a pull configuration. Sunon's and Panaflo's aren't as loud as they look. it's more important to be pulling air through the rad than it is to have a lot of CFM in free air, it's a radiator not a case fan..
A 360 rad (especially a slim rad like a black ice) is a little undersized for three cards if you consider each GPU would only have a single 120mm rad worth of cooling area, so it needs all the airflow it can get.
Lol, I got rid of that case guys. Went to a 780T, and now a Enthoo Luxe, running a 360 push/pull, and a 200mm Rad in the front.
Love Phanteks cases. What GPUs are those 3?
Come help the team out crunching once in a while ;)
