quiet compressor
Hello
What is considered as good very quiet compressor today for SS .
i have a modded vapochill ls with nf 5.5clx which is very noisy seating on my garage for long time . i plan to swap this compressor for something better .
do the NL11F still the best option for noise/performance ratio or there are better newer model .
I just found a deal in local store for a NL11F (used) for few pennies . :-)
Danfoss is pretty much the best unless you can find an Americold.
Just be aware the NL11F is 220v
Thanks for reply , yes i am in Europe so 220v is what i need :-) .
Americold is not available here .
Also any idea what is the captube size (inner diameter )of default vapochill ls ?
If you stick with the 1/2HP
.28 @ 66" ~ 72" for capacity
Thanks again ,
One more question , i had a leak in the connection between stainless steel tube ( that can bend and flex ) and cooper line , i am searching now for best why to braze it , most people recommend 45%(silver) and white flux . what do you use ?, i do not want to burn the stainless steel or cooper oxidation due to high temp .
